w/screen fitters
Old 13-10-2009 | 01:01 PM
THE RADMAN's Avatar
THE RADMAN
Default w/screen fitters
do we have any on here? ive got to remove a bonded in screen and wondered whats best way? i did one a few yrs ago but it was hard work and wondered if there are any proper tools available to cut it out?
Old 13-10-2009 | 01:22 PM
The Youth.'s Avatar
The Youth.
I have this one nick
http://www.tooled-up.com/Product.asp?PID=15632
steve
Old 13-10-2009 | 05:34 PM
THE RADMAN's Avatar
THE RADMAN
cheers steve,does it do the job ok? which size blade does it come with as there are a few diff ones available for it
Old 13-10-2009 | 07:10 PM
The Youth.'s Avatar
The Youth.
I didn't really expand my answer too much but in all honesty I have never used it!! lol
I have 2 sizes of blades I think 20mm and 15mm I have seen an identical one used and it did the job fine
steve
Old 13-10-2009 | 07:22 PM
Thrush's Avatar
Thrush
Irritating c........
The link Steve posted is for something commonly referred to as a "Kent" knife, or "Cold" knife. Staple part of windscreen removal, however, not really something you want to use a) if you've not used one before, and b) for removing screens in one piece (ie, not breaking them) as very rarely can you get a screen out without damaging it using a Kent Knife.
The most surefire way is to "wire" it out - you use two of these;
and a length of square "cheesewire". Run it round the outside of the glass, poke it through the bond at the bottom, attach to handles (inside car) and cut the screen out by pulling the wire through the bond line into the car. It's not easy, takes a lot of strength, need to know what you're doing as you'll either chomp the car/trims/dash to bits or just snap the wire - and punching yourself in the face when the wire snaps is not fun!!!!
When I was at Autoglass, I had a VERY cool tool designed to use that wire, that was on a ratchet system, and made cutting screens out in one piece much much easier. Man I miss that tool!!!
Old 13-10-2009 | 07:33 PM
THE RADMAN's Avatar
THE RADMAN
cheers for the info,last time i used a wire but it kept breaking but didnt matter too much as the screen was knackered anyway,this time i need to remove one from a donor car so i have to get it out in one piece,not so sure now
BM08
22-05-2008 05:32 PM
Mark_
02-03-2008 06:10 PM
BillyCabrio
55
02-12-2006 07:50 PM
RWD_cossie_wil
18-09-2005 03:33 PM
