help!! need oil pump info
hi im doing a sap rebuild and ran into a problem, when i was swapping the oil pump over i took out the two 10mm bolts and pulled the strainer of but somthing fell out of were the small pipe that sprays the oil up the under side of the pistons at the pump side and this happend on my stoney drive so i cant find i used magnet still nothing, dont no wot im looking for cus i only heard it so can anyone tell me wot it is or should i say was!!
did you take the pump out then heard something fall out? and is there now no pump on the block,. if so check that 2 things,, 1. the dizzy/oil pump driveshaft hasnt fallen out.
2. the locating dowel for the oil pump hasnt fallen out.
Cant be anything much else except possibly a washer or bolt?
jonfoc
16
11-09-2018 05:35 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
