Whose speedo is out with bigger wheels?
right since ive put 17's on my rst ive felt as if the speedo must be out so ive spent the last half hour working out how to convert my reading on the speedo to my actual speed.
I think ive done it correctly as my math skills are normally pretty hot
Diameter = 2πr
17” wheel:
40mm = 1.574 inches
17+1.574= 18.574
18.574 / 2 = 9.287 = r
2 x π x 9.287 = 58.352 = Radius
1mile = 63,360 inches
In order to travel 1mile must do 1085.824 revolutions
15” Wheel:
50mm = 1.969 inches
15 + 1.969 = 16.969
16.969 / 2 = 8.4845 = r
2 x π x 8.4845 = 53.310 = Radius
In order to travel 1 mile must do 1189.083 revolutions
1189.083 – 1085.824 = 103.259 less revolutions to reach the same speed
15” wheel at 60 mph is travelling at 1189.083rpm
17” wheel at 60 mph is travelling at 1085.824 rpm
Speedo speed / 1085.824 * 1189.083 = Actual speed.
103.259 / 1085.824 * 100 = 9.51
9.51% increase to speed shown on speedo.
100mph * 1.0951 = 109.51mph
Let me know what you think?
Diameter = 2πr
17” wheel:
40mm = 1.574 inches
17+1.574= 18.574
15” Wheel:
50mm = 1.969 inches
15 + 1.969 = 16.969
Is it possible to adjust / calibrate this to read the speed correctly?
Mine is fitted with 17" wheels (that`s how it came from Ford) and it seems to read higher than the actual speed.
I`m under warranty so can go to the dealer if required.
Thanks.
Thanks.
just get a sat nav thats what i use these days,i find that nearly all cars are out by around 5 mph,if ya doin 30mph your realy doin around 25mph and thats in all the cars/vans i drive
Regarding your first line of calcs:
Circumference = 2πr, not "Diameter = 2πr"
In your calcs too, your "Radius" should be circumference.
I could do with curing the error.
As ford fitted the wheels surely if a recalibration is needed they should have done it.
The cars a Ford Direct 59 plate I just want to know what i`m talking about b4 I go back 2 the dealer unless it`s an easy fix.
I was looking at the calibration of the MPG trip computer and thought it could be the same idea.
Thanks for the replies.
I have 17" wheels fitted instead of 15" and when driving along at 70mph on the speedo if i check againt my garmain sat nav this says 68mph so not bad.
McGarrity Motorsport
Your out the tyre isn't 40mm it's 40% of the width of the tire
so a 215/40 r17 is actualy 86mm tall
so it's 43mm of tire
isn't as far out as I thought it would be
Adam Graham
06-09-2015 06:04 AM
