Plumbers / boiler maintenace people???
Old 24-09-2009 | 08:37 PM
GINGExR2 T's Avatar
GINGExR2 T
Default Plumbers / boiler maintenace people???
I have a Worchester Bocsh 40CDi boiler. Boiler works/ed fine until a few days ago when the hot water stopped working, After opening the inspection panel i fould the digital panel flashing "EA", after resetting it's working fine but is now flashing "SE" , anyone know what this means.
Cheers, Ginger
Old 24-09-2009 | 08:42 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
It means it needs servicing.
Old 24-09-2009 | 08:52 PM
3drpete's Avatar
3drpete
it stands for (service engineer) mate it flashes up after so many hours use, theres a way of restting it wich i cant remember lol, but i got the info from the boiler helpline, the (ea) code is flame failure, it could of just gone out as (one of those things) but best to get it checked to be on the safe side.
hope this helps
pete
Old 24-09-2009 | 10:03 PM
patton16i's Avatar
patton16i
Back in business
How do mate i work for bg these boilers are normaly v,good if the hot water has stopped working chances are it needs a new hotwater valve fitted the hot water is controlled by a rubber diaphram in the hot water unit over time the rubber perishes and splits once this component splits it wont allow the hot water circuit in the boiler to work properly
Old 24-09-2009 | 10:12 PM
adsrs1's Avatar
adsrs1
yeh it needs a new diverter valve
Old 25-09-2009 | 05:32 PM
GINGExR2 T's Avatar
GINGExR2 T
I think i'll get it serviced as it's just coming upto 4 years old now and ain't had it touched since it was fitted.
Thanks for the replies.
Ginger
Old 25-09-2009 | 06:29 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
if it does need a DV give me a shout mate i might be able to sort you out but I dont think it is tbh like said EA is a gas/flame sensor problem
mk3ste
17-10-2021 11:09 AM
Rsmat
89
12-10-2015 08:50 AM
Adam-M
Was It You?
01-10-2015 08:55 PM
rsguy
44
29-09-2015 04:29 PM
