external wastegate fitting..?
Old Sep 19, 2009 | 06:26 PM
gibbo frst's Avatar
gibbo frst
Default external wastegate fitting..?
hi..
has anyone had a problem fitting an external wastegate and had it hit the brake resovoir on a 2wd cosworth.. has the correct spacer fitted in the manifold and take off welded on but looks like it needs another inch moving to clear it...
thanks for any advice..
jay
Old Sep 19, 2009 | 07:20 PM
gibbo frst's Avatar
gibbo frst
found on the search that their are differences on some of the brake setups in the bays maybe the 4x4 and early 2wd im not sure where but does anyone know if they are interchangable.. ?
thanks
Old Sep 19, 2009 | 07:36 PM
OrionRST200bhp's Avatar
OrionRST200bhp
sort of off topic. ive been thinking about external wastegates when do you need to fit them to a cosworth? do you need to be running huge power?
Old Sep 19, 2009 | 07:57 PM
gibbo frst's Avatar
gibbo frst
not sure if theirs a power level that u need one but the turbo ive brought needed one but they do an internal gate version.. .. if im honest i like the look of them in the bays thats all for me.. im not after big power i just get bored quickly and fancied a change ..
Old Sep 20, 2009 | 03:34 PM
gibbo frst's Avatar
gibbo frst
found that some have had the same problem but not seen any solutions for them.. few pics ive found showing the prob but cant see how they are different..
anyone have any advice please
Old Sep 20, 2009 | 04:14 PM
polly_x's Avatar
polly_x
The wastegate pipe cut and rewelded to avoid the brake resevoir mate. Surely thats the simplist and safest option. Are you sure you have everything on how it should be as thats a pretty standard conversion really?
Old Sep 20, 2009 | 04:43 PM
gibbo frst's Avatar
gibbo frst
everything is brand new and i cant see how i could have fitted it wrong as only looks to fit one way round.. ive found in the search on here someone had the same problem that his setup fitted in his saff then when swapped the whole lot over to a 3door it hit the res.. ive pmd him and am waiting a reply.. ill call where i brought it from tomorro i thought it might be a common problem.. its a pain to have it re welded as ive done another 300 mile trip just to get this one.. if i have to have it done then i will.. ill wait on stu @ claims centre to see how he resolved his... dont really want to fit a 4x4 set up..
Old Sep 21, 2009 | 11:30 AM
Had major problems with that on Roosie's 3 door track car, supplied by Reyland, but hit BIG time, it was cut off and re-welded where it didn't cause problems only thing you can do.
His big wing sump leaks though!!
May 31, 2016 09:28 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
Aug 14, 2015 07:29 AM
