fault code readers.........
Old Dec 21, 2004 | 04:49 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default fault code readers.........
are they any good ?????? for a 3dr....
Old Dec 21, 2004 | 04:52 PM
gearboxman's Avatar
gearboxman
My Snap-On reads my (3dr powered) Transit
Old Dec 21, 2004 | 04:58 PM
Azrael's Avatar
Azrael
Another "fastest" service truck around :-DDD
Old Dec 21, 2004 | 05:13 PM
chester's Avatar
chester
Danny
the engine loom will allow you to self test without any gizmos. If I remember rightly, by the ecu is a 3 pin connector on the loom - if you put a wire to connect the bottom two outlets together then the red ecu warning light by the clock will flash the code sequence if there are any faults.
The codes are listed in the workshop manual (if you dont have one post up the code and I will check to see what it is). They are not stored by the ecu though therefore if you switch off the ignition the code is lost until the fault occurs again
Hope that helps
Old Dec 21, 2004 | 05:59 PM
dannyblackpool
Boost Builder
aint got any faults at mo.................. i think
Old Dec 21, 2004 | 10:17 PM
Jim Galbally's Avatar
Jim Galbally
on a 3door, you use the std light anyway so pointless getting one.
for a saph etc. it does come in handy as it saves a lot of feckin about with LEDs and bits of wire otherwise...
they're not NEEDED to read out fault codes etc, its just a hell of a ot easier to do it wth one, so for the sake of a tenner worth getting
also buy the one for the EARLY model cars even if you wanna use it on a later model, as the early one fits all sockets (inc later ones )
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
