help over heating problem on 3i !!!!
Old Dec 21, 2004 | 08:04 AM
xr4x4rs's Avatar
xr4x4rs
Default help over heating problem on 3i !!!!
last nite my shed of a escort xr3i decided to overheat that bad the temp gauge was almost coming back on itself.
straight away i thiught headgasket i managed to get the car home noticeing white smoke coming out of the exhaust
as i pulled up loads of steam from under the bonnet which i thought pressureised due headgasket and water everywhere
on closer inspection i took the head off to find gasket intact
i have noholes in rad or hoses
so what elese could it of been to cause this pressure and overheating any ideas
i pick my head up at 12 today and getting new rad to see what happens
could the thermostat cause this aswell as im unclear if it could or not
any help much appreiciated thanx
the fan was on aswell
Old Dec 21, 2004 | 08:23 AM
NUTS RuS's Avatar
NUTS RuS
Where was the steam under the bonnet coming from ? There's obviously a leak there somewhere, or it could have been just a blocked breather cap on the expansion bottle. Any residue of oil / mayo in the expansion bottle or dipstick ? My guess is that it was the headgasket even though you couldnt see why. The new rad will help circulation, and you can check the thermostat is working by removing it and boiling it up in a pan of water to see if it opens. good Luck
Old Dec 21, 2004 | 08:41 AM
Oranoco's Avatar
Oranoco
IS the water pump working as I cooked my old Escort Ghia when the pump went pear shaped. A new pump is only about Ł20 from Halfords
Old Dec 21, 2004 | 08:42 AM
xr4x4rs's Avatar
xr4x4rs
there was no oil/water mix this was the wierd thing
the steam was coming from the expansion bottle i think or the rad but neither are damaged in anyway no holes cracked nothing
also could i use a turbo headgasket on the car aswell cause i have a spare headset here for a turbo
headgasket is still intact
i just hope its all fine today as i havent dun mw xmas shopping yet and need to do it tomorrow
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Rammer46
Sep 18, 2015 08:31 AM
cossie09
Sep 10, 2015 06:56 PM
BRAM
Sep 8, 2015 07:11 AM
