skyline gtr gearbox questions
can they be switched between 2wd and 4wd
which box is best to use (r32,r33 or r34)
what sort of power can they handle as standard
how much bigger than a 4wd cossie gearbox are they
any help is much appreciated
All skyline 4x4 boxes can be switched to 2wd, but only the 32 box can be ran 2wd without causing centre diff damage.
33 and 34 boxes will drag the centre clutch and overheat in time.
Big bonus is the power they can take, but there big
so i need an r32 box then
is there much work needed to the tunnel to clear the box
where would i get a pump from,with the pump running whats the torque split like
how does the speedo work is it electronic or cable
saw the pics mate but not much info with them thats all so just wanted to make sure i had got everything right,who welded the bellhousing on for you,did you have to modify the tunnel much to fit the box,is it an expensive conversion after the box has been bought
cosworth parts specialist
the pics i posted are of a r33 gearbox,the 2nd is of the pump to run the box. i used these in my mk4 escort,with cos 4x4 conversion.there are quite a few on ebay,so have a search,and you can see the differences to the r32 box.
you will need to extend the tunnel by 30 cm on the drivers side for the transfer case,and up by 15cm around the gear lever.
you will need a rear prop making
hydraulic center push clutch
if you use the liner pump,you will need a controller from reyland
i used a mocal oil pump,and a return valve to vary the pressure,worked very well.
0 to 50 in 2.3 seconds,
martin should be able to get the bell housing welded for you.
i need to get a rear prop made anyway mate as its going into my mk4 escort estate so thought while im still doing all the metal work i would do this save doing more work after the car is complete,i will give martin a call one day this week or next week,do you have any pics of the tunnel mods atall please,what did you do for the front prop
i guess they are too much trouble,for little profit.
fixing the new bell housing on,has to be precise,flat machined surfaces.so the the box needs a complete strip down.
iam sure martin still does the 11k conversion,to the os gieken box
ive never been in a car that launches like a 500bhp skyline, it just gripped and went
plus theres a lot of work involved, like half the tunnel needs to be modified and you can never go back to a std gearbox again, due to taking out the original gearbox mounts, custom props made, hydraulic pumps for 4wd system, custom bell housing, clutch, and hydraulic clutch conversion, custom gearbox cradle, theres loads of worked involved in doing the conversion properly, ive been looking into this since it was started being done, and even had llyodd do my tunnel ready on my sierra but scrapped the shell lol
was sriously wanting it for the escort cos as i can get a skyline gtr box ad eerything easly, its just the bell housing im struggling to find sumwhere to do, but now im going to stick with a bara i think
trouble is my car isnt completed yet and have still got loads of work left to do on the shell thats why im looking into this conversion as a bit more welding isnt a problem on mine at the moment,do i need to use a cossie bellhousing or is there another bellhousing i could use instead
Seems likeit could be the answer if the rest of the fabrication work wasnt such a pain in the arse. I presume onece this is all done the OSG box would just all bolt up if you wanted to upgrade?
what mods are needed for the front prop then or would it be easier to give you a call one day next week if thats ok to find out from you what work is involved and what is exactly needed for the conversion,i need to find out what clutch to use aswell and will i definately need the centre push hydraulic clutch
ive read on gtroc some clutches are push some pull dependent on age.
