Spec thread
Old Aug 25, 2009 | 05:05 PM
Pob's Avatar
Pob
Default Spec thread
Just an idea really, is it worth doing a spec thread for the sole purpose of showing the spec of your car with main emphasis on performance and what you've had done to do (everything listed-if not standard)
Obiviously with a few photo's per reply? +with or without replies because i'm sure (old or new hens) will get into a debate on one matter or another.
Just curious to see all cars from a 1.1 fiesta to a monster cossie?! I know people have build threads but some times you don't know all the inns and outs
Example i was thinking of (its worth doing/please add your opnions/modify)
Your name
car name
What car is it
Engine
Interior
Exterior
Suspension
0-60
1/4 mile times
Misc mods
Pictures (5 in total)
Thats about it...?
Old Aug 25, 2009 | 06:03 PM
JamesH's Avatar
JamesH
Engine - 2.0i 16v Turbo
· L6 ECU
· Fully Live Mapped by Karl Norris
· Full Home Engine Rebuild
· Group A Head gasket
· Wire Rung 205 Block
· 4x4 Pistons +1mm
· 7.8:1 Compression Ratio
· K&N Filter With Alloy Trumpet
· T34 Hybrid Turbo (0.63 Exhaust Housing) With 360° Bearing and Cut Back Blades
· -31 Collins Actuator
· 2 Stage Boost
· RS500 Turbo Damper
· Radtech RS500 Style Alloy Intercooler
· Samco Hoses (Boost & Ancillary)
· Group A Coil
· 3 Bar Map Sensor
· Green Injectors (Bosch 803)
· Group A Bosch 044 Fuel Pump
· Bailey Breather System
· Alloy Header Tank
· Alloy Swirl Pot
· Alloy Power Steering Tank
· Alloy Cambelt Cover
· Alloy Turbo Heat Shield
· Chrome Strut Tops
· Blue Cam Cover
· GGR Dump Valve
· Stainless Steel Single Box Scorpion Exhaust
· Boost Spike of 28psi, then slowly dropping to 22psi for the limiter (7250rpm).
Transmission
· Alcon 6 Paddle Clutch
· Fully rebuilt T5 Gearbox
Suspension
· Top Adjustable Koni Shock Absorbers
· LEDA Springs Wound to Ahmed's Spec (Fast Road)
· Adrenaline Race 6° Adjustable Rear Beam
· Poly Bushes Throughout
· R&B Motorsport Poly Rear Diff Mount
· Rear Strut Brace
Brakes
· AP 4 Pot Callipers
· 330mm Grooved Discs
· Ferodo DS2500 Brake Pads
· 4x4 Rear Calipers
· 300mm Rear Disc Conversion
· Apec Rear Brake Pads
· DOT 5.1 Brake Fluid
Wheels & Tyres
Front:
· 7.5"x17" Compomotive MO's
· 215/40/17 Eagle F1 GSD3 Tyres
Rear:
· 8"x17" Compomotive MO's
· 235/40/17 Eagle F1 GSD3 Tyres
Exterior
· 4x4 Vented Bonnet
· Clear Front Indicators
· Smoked Side Repeaters
· Laguna Front Splitter
· Cut Down Front Numberplate
· Late Spec Smoked Rear Lights & Number Plate Surround
· Small Cosworth Badges In Place of Sapphire Badges
Interior
· Full Raven Leather Interior
· Black Dash
· S.E.C.S Monitor
· Carbon Fibre Gauge Holder
· Carbon Fibre Steering Shroud
· Nomad Pillar Pod
· Nomad Boost Gauge (30PSI)
· Nomad Oil Pressure Gauge
· STACK Oil Temperature Gauge
· STACK Wideband Air-to-Fuel Ratio Gauge
I.C.E
· Kenwood Head Unit
· 2 6x9 Pioneer’s On Custom Rear Shelf
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
