electric power steering
was doin' some work on my m8's motor today and wondered if any one had fitted an electirc steering pump on an escos and if so is any info available
how did you go about finding out what pump to use, ie:what pressures they run at compared to an escos mechanical pump, cos i cant find anything
Originally Posted by markk
i take it this could be fitted to a fiesta if i had all the bits? i knowm some came with power steering but a electric pump would be a lot easier
Testing the future
most cars come with electric pas pumps these days. probably most common (and therefore cheapest and easiest to get hold of) are vauxhall astra, corsa etc.
the only difficulty i see is mating them to a ford steering column and making some hoses up to take the pressure. and mounting them so that they don't vibrate the whole car to pieces.
the citroen one is a stand alone unit fitted on the NSF chassis rail, it has power to it as soon as the engine is started' then all you need is to connect up the pipes from the existing pas rack
sorted!!!
sorted!!!
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
07-10-2015 12:56 PM
