fuse box
Originally Posted by escort1989uk
pull on the cables it will pull the fuse board out revealling three cross head screws undo those and there you go bobs your uncle
well i shocked it has taken people this long to help you out. sorry about peeps on here the get less helpful every day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
you cant take "just" the fuse board or case out ... have to pull the whole loom out of car throufgh the hole once you have undone the 3 above mentions self - tappers
how do you get at it etc,does it unplg somewhere
formerly uyo1972
if your just lifting it up slightly,you will be ok, look inside the car, above the pedals, you will see the loom, i just made sure the cable ties holding everything tight, were cut, it then gave me a chance to lift it up, a little bit, just dont pull the wires about too much, or you might have problems later, if you look at the box, without the cover on it, get a thin screwdriver, look for a hole, "cut out " at the front edge, nearest you, on bit with the fuses in, then "pop" it out of the casing of the fusebox, revealing the screws, , as its been mentioned, it is easy, once you have done it once, good luck,
dave
dave
formerly uyo1972
yeah it unplugs... off the back of the dash, switches, door loom at A pillars, rear lights, fuel tank ... etc.... aint simple im afraid
cheers damo, i didnt know it was like that to remove it completely ,
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
