cvh build time!
cvh build time!
hi guys looks like the fiesta engine has given up again. damn turbo cvh! just wondering what my best options are. does anyone know what sort of power and boost the pistons on cvh turbos can take. im hoping to build an engine that i can reliably get 200 hp without going for forged pistons as cash is tight! its an efi setup with a 195 chip, beige injectors t285 t2 cam, t3 turbo etc. anything else i should be aware of? oil pump and gaskets go without saying along with head rebuild!
cheers, mike
cheers, mike
so for 220hp can i reliably run the std pistons and rods and not worry about melting a piston. dont want to build it and blow it straight away! want to build and track day it!
I would personally build a zvh, but if you have it in your head to build a cvh i would replace the rods and defo use arp big end bolts as ive had both these items break in turbo'd cvh's, melting pistons will be down to mapping if you ask me.
steerfromdarear
28
29-01-2016 06:14 PM
Ben26
27-08-2015 08:56 PM
