Roll cage question
Old Dec 17, 2004 | 12:21 PM
AJ Escos's Avatar
AJ Escos
Default Roll cage question
can a weld in multi point cage be fitted without having to remove the roofskin
Old Dec 17, 2004 | 04:38 PM
mikelmr's Avatar
mikelmr
yes cut holes in the floor to drop the legs through, weld all the way round the top of the tubes, lift it back up a weld the holes up and fit the reinforcing plates etc. thats they way I've been told its done. Make sure you pick and choose very carefully who you get to fit a roll cage as I've seen some really dangerous attempts !
Old Dec 17, 2004 | 04:53 PM
tiny's Avatar
tiny
As above, thats exactly how mine was done.
Old Dec 17, 2004 | 05:09 PM
Lee @ Fusion's Avatar
Lee @ Fusion
if you cut the main hoop in the middle , colps the cage and put it in , then reweld ,thats nother way but you loose a lot of the strength of the main hoop then ,
another way is to loose 3 or 4 inches off the bottom of the main hoop legs , this will give you room to manouver , by the time you have the missing inches welde back o , boxed in and a couple of strengheners itll be as strong as ever .
Old Dec 17, 2004 | 05:40 PM
markk's Avatar
markk
as lee said , the cage needs to be approx 3-4 inch shorter on the main hoop , you then weld the top all round , lift up into place and make lower support boxes below the feet , your supposed to strengthen the floor anyway
Old Dec 17, 2004 | 06:49 PM
AJ Escos's Avatar
AJ Escos
cheers for the info
boeb
Jan 9, 2020 05:11 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
SMILER258
Sep 28, 2015 09:04 AM
Mikersturbo
Sep 27, 2015 07:43 PM
