Help Needed (Building engine back up)
Old Aug 5, 2009 | 07:11 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Help Needed (Building engine back up)
Hi Guys
Im stuck putting all the bits back on my just rebuilt engine. Im ok with most of it and to be honest its nearly all together
However im stuck with one bity at the moment which is.....
I have a long wire with a crank sensor on it a knock sensor on it and a metal bracket with 2 plugs on it.
I cant see where the bracket bolys too and i think the knock sensor goes on the rear or the turbo side of the block which means the cable has got to run around the rear of the block on top of th gear box.
Does anyone have any pics to help me as im majorly stuck and i cant put engine in until ive sorted this problem.
Thanks Guys
Rob
Old Aug 5, 2009 | 08:06 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
from knock sensor just above sump level under turbo, it travels towards the front, bolts to the sump bolts (the long ones iirc) crank sensor obviously is at the front, and the plugs and bracket fix to the block behind the dizzy
Old Aug 6, 2009 | 06:27 AM
Ebonycossie4x4
Thanks mate, There are 2 bolt holes on a diamond shaped bit of metal does it bolt to that.
Im suprised it goes round the front, seems a lot of wire for that, itl looks like it should go round the back.
Old Aug 6, 2009 | 04:47 PM
JTECH James
Passion for Fords!
yep it bolts to the block blanking cover on the side
JoeyBoyden
Jan 4, 2024 02:36 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Sultzi
12
Aug 16, 2015 01:08 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
