escort rs turbo question?
just wondering what the sensor is called on the inlet manifold, its a green plug and it is located underneith the brake servo pipe, i am wondering which side the car does the wire come from to plug into this sensor... also would this cause problems if it was not plugged in??
also wondering on a round about price on piston rings and shell bearing...
and if you do replace the shell bearing do you need to regrind the crank?
thanks for your time....
muz
16-08-2015 12:57 PM
