xr2 brakes
xr2 brakes
hey guys hope you all had a good day at the ford fair unfortunatley i put my fezzer in for retest saturday morning and the inspector found another issue so i was unable to make it i wanted to get up there to have a look at some of the guys brakes
i want to do a cossie conversion but i believe the hubs are different to the erst although inm sure i have fitted a caliper from my xr2 to a s1 before?
any of you guys got any solutions for me other than going to someone like hi-spec?
i can get brand new cossie calipers for 55 all in so would be a great start if i could find away to fit them
would really appreciate your help
Tony
Tony
Assuming there 4wd single pot callipers and not the 4pots, then they will bolt on the xr2 with rs2000 discs (260mm).
If you want to use cosworth discs you need to make/but brackets to space them out.
