ford focus 03plate letting water in! Help.
The scuttle panel on the windscreen in front of the passenger side will need to be re-sealed or replaced. It leaks onto the pollen filter which then drains into passenger footwell. The scuttle is replaced as a matter of course by some windscreen companies when replacing the screen.
Parking the car uphill makes it worse.
Yup easy fix that one. When they take the panel off to replace the pollen filter the clips break.
You will see that underneath the passenger side wiper the panel will not be sealed against the windscreen properly.
Ford have a modication for this common fault, which is a piece of adhesive foam to fill the gap
Get some new clips and do it properly
after pollen filter cover leak the other common thing on early focus's is the heater box leaking with condensation from a/c although pipe may seem clear.dash and heater box,strip box and seal job im afraid
