ecu swapping???
Old Jul 26, 2009 | 04:59 PM
daz2713's Avatar
daz2713
Default ecu swapping???
hi all,
i'm a new here to passionford here goes my first question.
I have an s reg st24 and i have made the mistake of buying a second hand superchip which does'nt work in my ecu (just turns over and won't fire up?) i have managed to get hold of the ecu the chip came from which is also a s reg st24, and this brings me to the question can i swap them over without any problems???
Old Jul 26, 2009 | 05:00 PM
paul16v's Avatar
paul16v
Monte 087
No it wont work.
Old Jul 26, 2009 | 05:40 PM
daz2713's Avatar
daz2713
will it cause big problems?
Old Jul 26, 2009 | 05:43 PM
paul16v's Avatar
paul16v
Monte 087
The car wont start or run with a different ecu fitted bud, the ecu chipkey & transponder are all tied in together you would need the key or at least the chip from inside it and the transponder ring from the mondeo you got the ecu from for it to work.
Old Jul 26, 2009 | 05:46 PM
daz2713's Avatar
daz2713
ok fella thanks for the reply i wont bother attempting it then.
Old Jul 26, 2009 | 05:48 PM
paul16v's Avatar
paul16v
Monte 087
Sorry i may have missread what your asking here, you will be able to swap the chip from one ecu to the other but if you swap the full ecu that is when you will run into problems.
Old Jul 26, 2009 | 06:04 PM
daz2713's Avatar
daz2713
i plugged the chip into my ecu but it would'nt fire up just kept turning over???
Old Jul 26, 2009 | 07:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Have you activated the port on the ECU?
Old Jul 26, 2009 | 08:48 PM
daz2713's Avatar
daz2713
no how do i activate it? just scraped off the lacquer and connected the chip to the terminal lug. does the superchip need to be preprogrammed to work with my ecu if so can i get it reprogrammed to work with mine?
Old Jul 27, 2009 | 06:04 AM
The port on many EEC's is disabled and requires some soldering to enable it.
You wil need to call superchips I guess mate.
Old Jul 27, 2009 | 06:40 PM
daz2713's Avatar
daz2713
ok thanks for the help.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
cossie brad
Sep 29, 2015 02:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
grishenko45
Sep 9, 2015 12:58 PM
