cossy won't run............
i have just fitted the following to my 3 doo,r i was running l6 ecu and loom
bd14 inlet cam
10mm inlet spacer
4x4 inlet plenum with 4x4 tps
siemens 83 injectors
4x4 engine loom
l8 ecu
chip from stu
the car won't run very well at all. its hunting on idle, some times i can get it to rev, when it does rev it revs ok but then it will start missing and back firing through the induction side.
all plugs are in the correct places (i've checked it against my mates 4x4)
any idea's? can it be the loom?
bd14 inlet cam
10mm inlet spacer
4x4 engine loom
l8 ecu
chip from stu
Passion for Fords!
yes swap the two outer wires
heres a few things to check
double check your cam timing,
zero the global mod screw
make sure you have no air leaks,(pressure test)
check and adjust the tps setting
check and adjust your fuel pressure, it may not have been running std pressure before, and it should be now!
check the earth wires on the loom are present and connected to the plenum tightly
check ecu voltage
check ecu voltage
check ecu voltage
check ecu voltage
how will i set the tps?
i think i'm going to buy a ryan loom to fix the problem
it's booked in for a live map in august at stu's, i just wanting to drive it to find any problems with the map he sent me.
Passion for Fords!
5 turns anti clockwise, then 2.5 turns clockwise will gert it close to zero.
to set the tps, use a multimeter and measure the signal voltage is correct at closed throttle and wot, also check it has a steady sweep
a new loom is always a good idea!
i have narrowed the problem down to either the chip, ecu or the inlet plenum and tps.
the inlet plenum can off i running car which i know, so i don't think its that so its either the chip or ecu.
i put my l6 ecu back on, injectors to match and my 2wd plenum back on and it runs fine.
what could cause my car to run ok for 5-10 sec's then miss like hell and won't rev with my new set up?
the spec of the chip is correct to what my receipt says
all part numbers are the same on the injectors (fi11405)
what do you mean by has the chip been checked? i bought it new from you.
after getting it running properly with my old set up. i tried changing just the 4x4 tps, injectors and ecu.
it still wont run after 5 seconds. i've reset the c02 screw on the ecu and tried adjusting it a turn either way but still running crap.
any ideas what to do next?
Russ Payne
25-09-2015 08:29 PM
