Stuck Cambelt Pulley
The cam belt pulley on my crank is seized solid ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
I've had this problem before - I had to drill and split the old one with a chisel, there was no way it was coming off.
It's too tight to get a normal puller in there - the manual shows a special puller for this (21-028 A), this is the only way I can see to get it off without resorting to breaking another one.
I don't suppose anyone has one they wouldn't mind lending me for a few beers, or anywhere that hires them out?
Cheers!
Neil.
Cheers!
Neil.
can't believe this has happened again to you!
did you clean up the crank before fitting it to ensure it wasn't a to tight a fit?
you could undo the alloy front plate and use that as a lever, I have a spare in me stash if you break it. I have done that before but it was on a pinto crank that was off the car so the risk of dropping stuff into the sump wasn't there tho!
steve
steve
The crank was as clean as a whistle Stevie, I coppaslipped it up before I fitted it too.
It'll bust that front cover for sure methinks.
I'll try heat but I can't see it coming off in one piece - Paul has some in so I'll just buy another if I bust it
ah right, is there no way you can make/modify a puller to go on it, cant be that hard, made a few pullers before when things have started to piss me off
muz
30-09-2015 08:29 AM
