Oil filter catalogue listing threads and diameter of sealing ring?
I need to find a catalogue of oil filters that lists each by its spin on thread and the diameter of the sealing ring.
I am trying to find out if there is a shorter filter available which would fit a volvo T5 filter head. I know going smaller is bad in theory but if I change it regularly (every 2 or whatever) it should be fine.
Even a gain of 10mm would be worth having
ok, quick search of: http://www.wixfilters.com/filterlookup/ by vehicle gave me this:
zoom
Part Number: 51311
UPC Number: 765809513112
Principal Application: Volvo (92-99), Kubota, New Holland, Volvo Trks + Buses, Mahindra Tractors
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.372
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=8/21
Burst Pressure-PSI: 331
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
I cant find a way to list filters like youd get in for instance a clutch catalogue tho. Going to be a long day searching thru all the filter part numbers one by one!
zoom
Part Number: 51311
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.372
Thread Size: 3/4-16
Gasket Diameters
ok, found the Australian company Ryco who let me search by seal diameter and thread.
http://www.rycofilters.com.au/catalogue/dimension
only one was shorter than the standard T5 filter (85.6mm) which was Z314 at 62mm
Rtcos site was then a little useless, but going back tot he Wix site I coul cross reference that number with the equivalent Wix filter and then look up applications which gave me Renault (68-84) and lotus europa (Part number 51335)
Part Number: 51335
UPC Number: 765809513358
Principal Application: Renault (68-84)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.483
Outer Diameter: 3.670
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 280
Gasket Diameters
15614 2.834 2.462 0.255
Should allow me to remove an extra inch off the sump and drop the engine by the same.
The only possible issue is the by pass valve pressure on the renault filter is the bypass pressure is only around half what the T5 filter is. I assume this will only become an issue as it gets clogged? (needs to be changed sooner)
Part Number: 51335
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.483
Thread Size: 3/4-16
Gasket Diameters
weight and cost and trying to route inflexible hydraulic hoses in a cramped bay and the fact that a closed ended takeoff plate is nigh on two inches thick anyway means its not worth while for this application I dont think. I had thought about it.
Ill need to look up the bypass pressure for the cossie filter....
I cant find any details on that cossie filter, it wont show up on WIX site like the others.
DOes anyone know if Im going to run into potential problems with the bypass pressure? Or will it just bypass in a less clogged state? Ie can I get around the lower pressure by changing it more often?
mrmann
20-08-2015 11:24 PM
Roosie
09-08-2015 07:37 AM
