What power level did the 3dr cosworths Jimmy Mcrae etc used to rally in the 80s??
As above, was watching a few vids on youtube and just wondered what stage of tune they used to run, would it be something like a stage equivalent??....
Chasing Radders
Never asked if they used the t3 or not but he did say they were tuned slightly so im guessing they would have the t3 albeit slightly modded to maybe spool faster.Not sure about the mantas but think it would be fair too say they probably wouldnt have 100 bhp more
Ban[B][/B]ned
C.R.E.A.M.
ahh the 3dr cosworth...
the proper early ones had engines done for ford by terry hoyle,so if you really wanted to talk turkey terrys the man for the early stuff.
Terry Hoyle Racing Engineers Ltd
Unit 5 / 6 / Heybridge House Industrial Estate
The Causeway
Maldon
Essex CM9 4XL
Telephone:
01621 850440
Fax:
01621 854495
when terry decided he didn't like turbos ford used mountune.
The Causeway
Maldon
Essex CM9 4XL
Telephone:
01621 850440
Fax:
01621 854495
or you could just ask jimmy himself on sunday at kaimes at the old school escorts day which im led to believe he will be chucking colins mk2 or a stobart mk2 about at
C.R.E.A.M.
red would do almost anything to get jimmy or colin to win a event, even if it ment fuckin around with the boost,illegal servicing.
in the old days john goff sat in r.e.d's tranny on the event rebuilding the boxes as the cars went through them so quick.
they also used to run colin in a group n car in the group a with just a big group a diff fitted to get it in.
he still won like in group n+ cars.
i was told the group a cars were well over 300 but under 400 btw.
rally engineering development the sierra cosworth specialists + jimmy mcrae
Got an article on the 1988 Corsica winning car here.
Cozzfather is right, Terry Hoyle built the engine in partnership with Graham Dale Jones from Boreham.
Ford Motorsport's John Wheeler reckoned that the standard turbo and intercooler limited power to around 308-315bhp but torque is over 300lb ft from 3500 > 5500 rpm
Getrag 5-speed box 4.89 rear end with viscous diff
Bilstein dampers set at front 325/150 with 500lb springs and rear 260/110 with 200lb springs
AP brakes 12.9 in front
11.2 in rear
Weight in Corsica trim 1106kg
Tested on a wet Boreham track by John Wheeler on Michelin slicks
0-30 2.4
0-60 4.8
0-100 10.8
Max 115mph @ 7500rpm in 5th
11.2 in rear
0-30 2.4
0-60 4.8
0-100 10.8
C.R.E.A.M.
11.2 in rear
0-30 2.4
0-60 4.8
0-100 10.8
11.2 in rear
0-30 2.4
0-60 4.8
0-100 10.8
Mike theres a problem with this !!!!
wait for it.................
its comming
no pic
didier auriol won it.
B1mbo
back in the early days of group a the turbo cars were running a 38mm restrictor over the 34mm
i would say they were around 360hp if on the bigger restrictor, i know the escorts were running this sort of power when on the big restrictor !
the torque would have been abit higher than the power, around 390 in the escorts, dont know about the 3doors
Good thread
Coldo loves seamen
I might pop along to Kaimes on Sunday, and if i see Jimmy, ill ask him. Not too far from me.
Ill tell him i know Dojj and his WWE crew and he'll give me all the info i need to know
Cosworth designed 16 valve head and Opel Rekord diesel bottom end
come along mate should be a great day and lets be honest how often are you goin to see jimmy mcrae chuck a mk2 escort about nowadays
matman
09-09-2015 05:45 PM
