Koni adjustables
Old Dec 12, 2004 | 12:19 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Default Koni adjustables
I have a set of red koni shocks and springs fitted to my sierra. "adjustable" is written on every shock absorber, but the question is,how do you adjust them? On previously owned cars with yellow konis on,a couple of tabs stuck out the top of the front struts, but the red ones don't have this,and i could never work out how to do the rear shocks.
Old Dec 12, 2004 | 12:21 PM
apples24's Avatar
apples24
??? at the top with the koni key?
Old Dec 12, 2004 | 12:26 PM
BRIGSPORT's Avatar
BRIGSPORT
There must be a different type of koni key on the red ones,as the yellow type koni key locates on the tabs that stick out the top of the front strut. As for the rears......
Old Dec 12, 2004 | 12:33 PM
Paul_RS's Avatar
Paul_RS
you have to take the shocks off push the rod thingy right down into the body then turn the shiey jobbie round you should feel it click into a groove, and then the groove bit should turn round. Well thats how the rears on my fiesta were done anyway! Sorry bout the amazingly technical terms used as well
Old Dec 12, 2004 | 12:37 PM
BRIGSPORT's Avatar
BRIGSPORT
If that's the case then "bollox",as i have just finished bolting the fronts on,at least the rears can still be checked. But i am non the wiser as to what a "shimey joddie" is?
Thanks for the reply.
Old Dec 12, 2004 | 12:42 PM
Paul_RS's Avatar
Paul_RS
lol! now mine were the yellow konis, dont know if the reds are exactly the same!
Old Dec 12, 2004 | 12:55 PM
R4N SS's Avatar
R4N SS
for the rears you have to take the shocks out
Old Dec 12, 2004 | 12:57 PM
BRIGSPORT's Avatar
BRIGSPORT
Then what do you do?
Old Dec 12, 2004 | 01:32 PM
BRIGSPORT's Avatar
BRIGSPORT
Old Dec 12, 2004 | 01:35 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
push the button and turn shaft
R4N SS's Avatar
R4N SS
u take the shocks out and adjust it with your key and then put em back
well u do on the yellow konis i have on my 3dr
Old Dec 14, 2004 | 01:56 AM
SS1's Avatar
SS1
on yellows turn left to hard setting right to soft
on the front use a pair of grips
on the top of the shock been told
Old Dec 14, 2004 | 01:59 AM
SS1's Avatar
SS1
think there is a wheel on the side u can adjust maybe
yatta
May 21, 2016 10:31 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
