Trackdays
Trackdays
help wanted i want to use my 2wd cosworth for some trackdays wot can i do to make the engine safe when on track [oil temp,oil surge and water temp] and anythink else? cheers
the you'll need a decent oil (pro s 10/50)
decent set of brake pads with 5.1 fluid
baffled sump is ideal
oil cooler
make sure you have no air locks, never hurts to give the system a flush and use the right ratio of antifreeze/summer coolant
it might help if you tell us what you've got already to be honest
trackday
The spec is a harry gibs rebuild with std compression,group a head gasket,t34,greys,500 intercooler,alloy rad,stainless exhaust,044 fuel pump with rewired,bailey breather,swirl pot and ap 6 pots with 355 disce. cheers
nico12
31-12-2015 04:42 PM
truffleshuffle
10-09-2015 09:35 PM
track.focus'd
12-08-2015 05:53 PM
