quick plumming question
Old Dec 10, 2004 | 05:29 PM
Gra's Avatar
Gra
Default quick plumming question
I am having lots of work done to my house in the new year, so have had a radiator removed from one wall in preperation, but the pipes are still there etc and the water flow to the removed rad is turned off by the bleed screws in the two pipes, now is it an easy job to wack the rad back in? and can i use them coupler thingys, the instructions say that there are intended to connect to bits of pipe in a central heating system but i wanted to check, heres a piccie of the coupler thingys
Old Dec 10, 2004 | 05:31 PM
Gee's Avatar
Gee
yeh mate but think you'd be better off using brass connectoer then solder em
Old Dec 10, 2004 | 05:37 PM
Gra's Avatar
Gra
i only want a quickie fix, as its only gonna be used for a couple of weeks
Old Dec 10, 2004 | 06:23 PM
Physio's Avatar
Physio
Yep those can used just as well as brass thingies
Old Dec 10, 2004 | 06:33 PM
4x4pete's Avatar
4x4pete
YOU can use the speedfit connecters but make sure the 15mm copper you are pushing into them has been cut with a pipe slice cos with a hacksaw the copper might fook the rubber o ring inside
Old Dec 10, 2004 | 07:01 PM
Gra's Avatar
Gra
cheers peeps
Old Dec 10, 2004 | 08:43 PM
cossieracer's Avatar
cossieracer
there are two types one which when you push it on you can not get it off without cutting the pipe again and the other that you can remove when you need to, but can also be used as a permanent fitting. The connector that you can remove is a lot bulkier and has a sort of inner piece attached with which you use to release it. permanent ones are just the one piece, not recommended if it is just a temporary measure.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
