compresion struts and adjustable tca's
land of the rising sun
Location: sheffield,home of james toseland world superbike champion
can you run compresion struts and adjustable tca's without a anti rollbar (i.e not standard 1) do you notice a massive difference with this set up on as to the standard polly bush way. wheres the best place to buy them anybody
does anybody have any pics
Caraholic
Compression struts:
Absolutely shit on the road
, the ride quality will just go down the toilet due to the high pondage springs you need to run with this set up
Adjustable TCAs:
My advice for a road car is to get the geometry right and fit some decent suspension. I would not put compression struts on any road car.
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
Adjustable TCAs:
Caraholic
Front suspension: Independent by LEDA gas filled adjustable dampers / platforms
with Eibach 2¼" springs. Macpherson struts, set to set to 2.25° negative camber (adjustable TCAs), 0" 20' toe in. Standard 29mm anti-roll bar with polyurethane bushes.
Rear suspension: Independent, by semi-trailing arms, LEDA gas filled adjustable dampers / platforms with Eibach 2¼" springs and standard 22mm anti-roll bar. Zoo Grp A 6° ream beam set to 2° negative camber and 0" 20' toe. Polyurethane bushes.
I ran em on my Mk2 Tarmac car and they were awesome, the turn in was very good,and geometry could be set perfect! however, they do go the rod ends dont last forever and they are pretty hard through the steering.
Testing the future
you can run compression struts as well as an anti-roll bar.
over here SUHE motorsport sell a kit (and i did have it fitted to my car when i bought it). you get the struts, a bracket to weld on the floorpan near to the arb mount, and some eyes to weld onto the tca at the bottom. so you run the compression strut effectively underneath the arb.
didn't get a chance to see how good they were as i crashed it into a tree after 10 minutes of owning it. i didn't cut the brackets off the old shell when i scrapped it, so haven't fitted tem to my reshell.
alternatively, you can always run an adjustable blade front arb going forwards as BROM has before.
zoo do the lot anti roll bar kits tca and comp struts
only really fit comp struts if going on track loads
how is your tyre wear mike running 2 deg neg ??????????
how long to they last
Testing the future
you can see the compression struts fitted to the tca's here, and see that it is still possible to use the arb
http://www.suhe-motorsport.de/Optimierung-1.html
i personally have and would use the compression struts on a road car , and never run silly poundage rates as that just due to inefficiant damping in you need to , but then i do pay good money for dampers !! - and i dont run arb's front or rear , as for how it handles - really crap - really really crap
Mark V8
13-09-2015 09:34 AM
