heeeellp
Old May 28, 2009 | 04:14 PM
It's Czech Mate's Avatar
It's Czech Mate
Default heeeellp
changin rear pads on mondeo.....cant get new pads into caliper, the piston doesnt seem to want to go back.....how do i do it?
ta muchly
Old May 28, 2009 | 04:15 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
On my Cossie you needed to rotate the rear caliper pistons to get them back in.
Wonder if the same on a mondy?
You can get a proper brake caliper pushing back tool for this exact purpose.
Si
Old May 28, 2009 | 04:20 PM
C4llyT's Avatar
C4llyT
If like a vw a big lump hammer and a joint splitter to act as the turning tool thing works for me.
Presume bleed nipples are slackened off?
It's Czech Mate
dont think i can rotate them
Old May 28, 2009 | 04:22 PM
groomers's Avatar
groomers
you have to rotate them best to use the tool.
Old May 28, 2009 | 04:25 PM
mcst's Avatar
mcst
My Focus and my old mundano needed the piston rotating back in. I used narrow nosed pliers and it wasn't the easiest but i didn't have the correct tool. Theres a cut out to locate on a block on the back of the pad too.
I'm getting a tool before the next time to save the grief.
takes a bit of effort to get started, try turning the opposite direction then back to get some movement. took ages on one side when i did them on my focus then the other side was a piece of piss!
Old May 28, 2009 | 04:27 PM
C4llyT's Avatar
C4llyT
Yeah lump hammer and something to rotate, 2 man job really without correct tool.
Old May 28, 2009 | 04:37 PM
Brian's Avatar
Brian
When i changed mine on my Mondeo 2003 i undone the brake fluid cap and then used a grinder disc changing tool to wind the pistons back in worked a treat
Brian
Old May 28, 2009 | 04:42 PM
saph4be's Avatar
saph4be
iirc one side is left hand thread but they deffo wind back i found sometimes you need to wind them out half a turn to get them to go HTH
Old May 28, 2009 | 08:06 PM
It's Czech Mate
Thanks chaps.....dead easy to turn without the tool, just build up caliper again without disc or pads on....its then mounted solidly and you can get to the bit you need to turn with some needle nosed pliers ( not nice ones you wanna keep tho! )
Old May 28, 2009 | 08:14 PM
matt.t's Avatar
matt.t
if youve already done it fair enough but buy the tool for next time,alot easier and not that expensive and you can change the bits for other cars.
