AP brake help
22-05-2009, 09:22 PM
AP brake help
My mate has just bought an escort cossie with ap front brakes with 330x20 discs,now the discs are screwed and judder like hell.
My question is would 326x30 discs be ok to use or is that to small?
cheers
22-05-2009, 10:02 PM
Wouldnt the 326x30 discs be too thick if he using 20 already?
Mart.
22-05-2009, 10:13 PM
Danger Seeker
Quote:
Originally Posted by
Moonstone Mart
Mart.
I thought that, unless he takes 5mm off each pad
22-05-2009, 10:17 PM
the caliper will be designed to take 20mm discs. 30mm discs will be too fat for the caliper
23-05-2009, 04:57 PM
oops my mistake the one already on are 330x30 lol no 330x20 like i said
so would 326x30 be ok rather then 330x30
24-05-2009, 08:02 PM
Dicko&Sarah
need help people,would this work.
24-05-2009, 08:03 PM
if your needing new disks mate giz a shout ill get you some on the cheep
24-05-2009, 08:45 PM
no where near what i can get them for i bet
25-05-2009, 07:17 PM
all i can do is try but if you can do better then you can help him
25-05-2009, 07:21 PM
should be ok thats only 2mm at the pad,, as long as surface area is ok
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
