Aeroquip help required
Im planning on making my fuel hoses this weekend so had a quick practice today! frayed metal everywhere ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I wrapped electrical tape around before cutting but made a right mess, whats the best method to use? (its -6 hose)
Also do i need some aluminium spanners for fitting connectors? and any tips for stress free fitting?
Used a long metal saw with masking tape, also did use a air saw as well
As for the fitting you can use special spanners but the kit about £200 so what i did is wrap the connectors with electrical tape
Also when but then ends on use some oil or wd that will help, when they are done make sure you clean out the hose, run under a tap that will make sure there is nothing in the hose
when i did mine i wrapped the ends with masking tape. I then cut through using a cutting disk in an angle grinder. This gives you a nice finish to the end plus you can remove any stragglers easy.
As for the spanners I used normal spanners but wrapped the spanners in masking tape as well as the fittings.
when pushing the fittings on you should push the fitting onto the pipe with a clockwise motion, keep turning the same way. Get the pipe so it butts right up to the inside of the fitting. To screw the final bit in, put the pipe and push on fitting in a vice, push the final bit in whilst turning to engage the thread. it should screw ikn easily, if it feels tight stop as you're probably cross-threading it.
cheers guys
ive got all the bits coming from think auto! am i right in thinking these are goodridge and as these are not teflon lined i wont have olives to worry about?
The union nut just pushes on first, they're normally tight as a twat but they do go on with a bit of persuasion lol. If you struggle with it you can clamp it in a vice so it's easier to push against it, just go careful not to mark the quip as it's pretty soft!
I use a couple of bits of aluminium in the jaws of the vice, also covered in masking tape. The unions i used were from pace products and the bit that grips on the hose is actually kind of threaded. Stick the union in the vice, push the hose in and twist it clockwise at the same time. Keep pushing and turning and it should go in with no problems.
When you've cut the pipe square, hold the pipe at 45 degress to the face of the grinder and just lightly tidy it up, as if you were de-burring the corner. it helsp to tidy up any stragglers. When i did my firdt batch i used a hacksaw to cut the hose and it was a nightmare to get into the union. Using a grinder I found it much easier and the finished articles were spot-on.
Wrap the hose in masking tape - mark where you need to cut it on the tape. Use a new junior hacksaw blade and cut. I find it best to only apply light force when cutting through, but keep the action of cutting fast.
When it's cut, put a single piece of electrical tape over the end and try to make it 'overlap' the newly cut edge, this then minimises any stray wires not going into the fitting.
Oh and if you are doing a lot of aeroquip - buy the plastic vice jaws from speedflow.co.uk to stick in your vice! (they are only 10 pound).
right ive managed to cut the hose with a disc cutter which worked really well, now im having trouble with the fittings.
This is my attempt eith a staight -6, i pussed the union right on till it butted up against the hose then screwed the fitting down! is this the right way to do it? and should i screw it right down till it touches sleave/union because it was quite tight?
![](http://i401.photobucket.com/albums/pp99/nath8282/DSCF0222.jpg)
![](http://i401.photobucket.com/albums/pp99/nath8282/DSCF0217.jpg)
or is this ok?
also ive been sent a speedflow 90degree fitting which is different to the others, i tried fitting this the same way but after pushing the union right on like before i had no chance of starting the fitting
![](http://i401.photobucket.com/albums/pp99/nath8282/DSCF0219.jpg)
any help would be great as i dont want to do this wrong or have to replace them
or is this ok?
1st pic looks fine mate, if it's getting tight you shouldn't have to do it up till they're touching....personally i've only ever fitted goodrich fittings so not too sure about the 2nd one, don't see why it would be any different to fit though?
and the 90 degree one i cant see how it will work, if i push the hose right in to the union nut the fitting gets no where near the catching the threads
Mmm sounds a bit odd...might be worth a call to where you got them?? Only rason i said about not bottominh out the threads is that it's what i was told at the place i buy all my aeroquip from....and when i've done mine i've never needed to bottom them out....they don't generally leak although in all honesty i had a couple of mine leak when i first plumbed my fuel system in (which may have been down to me not doing the mup as tight as i could)?!! but now on the fuel lines i use ptfe tape round the threads and never had one leak since!
There's not too much to be confused about....you've done them right by the look of it mate so don't worry!! I just wrapped some ptfe tape round the threads on mine, but i'm sure it's not really necessary, i was probably being overly cautious!
You don't need an olive for that fitting. The second fitting is actually better than the first one your pictured as its a cutter thread.
You fit it exactly the same as the first one but you will have to push it on harder to start the thread as the tube has to start downt he rubber hose. Then screw it down till one turn from the bottom.
IIRC its anti clockwise for the hose until its at the bottom of the thread then clockwise the fitting into it.
I put a little copperslip on thread just in case for removal, and finally mark the hose after you have screwed it into the first fittting just in case it backs out of the collar.
HTH
Dan
HTH
Dan
wowk
30-03-2021 07:49 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
