turkish block
Old May 14, 2009 | 06:55 PM
cozzy jeff's Avatar
cozzy jeff
Default turkish block
i have a turkish block with about one thousand miles on it,i know some people have had problems with them,but would you be happy useing it for around 450bhp?was thinking of getting 6 long studs put in,and also oil squirt jets,whats you thoughts?
Old May 14, 2009 | 07:01 PM
LHD220Turbo's Avatar
LHD220Turbo
its pot luck i'm afraid, some fail at 400 some fail at 600
if i was running more than 450, i'd rather have a turkish block long studded than a 205 block
Old May 14, 2009 | 07:02 PM
xrsi's Avatar
xrsi
out of interest what is a turkish block?
Old May 14, 2009 | 07:03 PM
LHD220Turbo
a copy of the 200 blocks made in turkey out of inferior materials - basically more prone to failure
Old May 14, 2009 | 07:08 PM
xrsi's Avatar
xrsi
ah right, thought it would of been something like that.
what normally fails on them? as if they are cheap enough would you not be able to line them with liners and long stud them?
Old May 14, 2009 | 07:10 PM
LHD220Turbo
they can fail at different places
liners dont stop them from failing, Dave (mad yum) had his lined and the liner moved and engine failed IIRC
although that was an extreame engine
Old May 14, 2009 | 07:12 PM
xrsi's Avatar
xrsi
ah right, thought being cheap materials the cylinders would of failed due to the pressure etc hence the liner question...
shame they are cheap materials as they would be worth weight in gold if they were decent... does anyone cast decent copies of the blocks?
Old May 14, 2009 | 07:26 PM
lee2cossies's Avatar
lee2cossies
How can you identify a turkish block? what numbers etc.
Old May 14, 2009 | 07:28 PM
LHD220Turbo
on the exhaust side of the block the numbers will begin or end (cant remember which) with 99
Old May 14, 2009 | 07:31 PM
LHD220Turbo
still quite a few 200 & 205 blocks about
Cosworth make an alloy block replacement, but have had no experience of them so cannot comment on strength, i believe mark shead at MAD was looking into them, there is a thread on here somewhere about them http://www.cosworth.com/shop_item.php?productid=470
Old May 14, 2009 | 08:36 PM
STUCOS's Avatar
STUCOS
Lots of new blocks that came direct from cosworth,were 99 blocks.bet there,s more about than you think,seen some big hp cars run them,until a few yrs ago,no body was aware of them
cheeRS stu
Old May 14, 2009 | 08:43 PM
rinus_2005's Avatar
rinus_2005
how can you identify a turkish block then? ( if i were to stumble on a 200 block)
Old May 14, 2009 | 08:51 PM
LHD220Turbo
on the exhaust side the numbers stamped will either begin or end (can remember which) with 99
Old May 14, 2009 | 09:07 PM
scoooby slayer's Avatar
scoooby slayer
got one in mine 5k miles at 2.2 bar t4 470 bhp and has been spot on touch wood.
Old May 14, 2009 | 09:09 PM
rinus_2005's Avatar
rinus_2005
Ah oke thanks,
and i believe i did read in an old fastford magazine Millington also has alu yb engines?
Old May 14, 2009 | 09:11 PM
LHD220Turbo
Ah oke thanks,
yeah i believe Martin @ Reyland has one in the Escort
Old May 14, 2009 | 10:56 PM
lee2cossies
Got a new block myself.Was told by the guy i got it from that its a belgium made block? the part number ends with 98.
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
