help with shift light?
Old Dec 7, 2004 | 03:24 PM
darren.cudd's Avatar
darren.cudd
Default help with shift light?
ok, ive got one of these fitted to my car but it came with a load of bits when i got the car so ive got no instructions
it has a speed shift function witch cuts the feed to the coil when you dip the clutch so you dont need to lift the throttle. problem is its pissing me off cause i normally heal and toe when changing down but with this fitted it just backfires when i blip the throttle
so does anyone know if im able to set it to not do this? one of the buttons is a "set shift" button and when i press it the function dissegages, but only till the next time i dip the clutch
anyone used one of these and know if i can sort it, or shall i just put a switch inline to the cutch wre
http://www.demon-tweeks.co.uk/catalo...CODE=AAE10SS01
Old Dec 7, 2004 | 03:49 PM
darren.cudd
up up up
Old Dec 7, 2004 | 05:13 PM
The Rapid 1's Avatar
The Rapid 1
Hope this helps
Never actually set up the gear shift bit as with nos fitted didnt fancy doing full throttle gear changes.
if u cant read it (photobucket seems to have resized it for me, making it a fair bit smaller) pm me an email addy and ill send it over full size
Steve
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
