Tropical Fish help
Blimey, you trying to fry your fish? Mine is at about 23-24 degrees. It all depends which heater you have.
If you twist it one way the heater should click on, all you need to do is twist it back until it clicks off, then twist it a bit more until you get the right temperature!
Yep you're correct my tank temp is set at 23-25 just checked to myself
I turned it down 2 clicks last night before i went to bed and its dropped down to 29 to hopefully it will drop more today or i will turn it down another few clicks.
Strange thing is, it was at 26/27 in my friends house. We moved the tank but didnt adjust anything on the heater and now its up at 30
I don't know mate, it all depends on what model heater you have. What you can do is remove the heater, put it in a 2 litre coke bottle or something with the lid cut off, then get the temp set right in there before you put it back in the tank.
Or another thing you can do is turn the knob right down to its lowest setting, wait for the tank to drop to the required temp (aim for 23-24 degrees), then very slowly turn the knob up until the heater clicks on.
That then should be your temp set!
Get on That!
leave part of the lid off this will allow the water to loose it temperature mine sit at 25c constantly and when its really warm i just leave the lid open and the water can then breath and loose its heat also turn the light off
higher temp=lower oxygen content= breathing difficultly= stressed fish, 29 aint over bad but would try get it down around 25, 30+ is a definiate no no hope this helps Dave
Get on That!
my ruby & silver sharks like it around 25c
but my corys & hoplo catfish like it slightly warmer any lower than 25c they get lazy and never ever move obviously cause bottom of the tank will be cooler than the top, i would also advise you have a good 5"+ airstone as this will disturb the water surface and allow the water to absorb oxygen
As said below it all depends on the fish you have. Turning the heat up a little can encourage certain types of fish to breed. I have Snakeheads, Oscars, Tinfoils and a Redtailed catfish and I find the best temp ranges between, 23 and 25.
Team HOTHOT!
I'm looking into getting an aquarium for just 1 breed of fish, but the temperature needs to be regulated at around 18 degrees - is there any way of doing this as obviously when the room temperature is 30 degrees then the tank temperature will bein to rise slowly
Get on That!
so either put the tank somewhere cool already and regulate with a heater or have it in the lounge and buy a water chiller to get the temperature down
Team HOTHOT!
Was thinking a water cooler - the fish in question is an Axolotl, and it would be in my bedroom
Now the temp in here can reach upto 32 celcius when the telly is on (massive plasma) and the fish don't like that sort of high temperautre - they tend to stop working and sink
Good place for cooler/heater regulators for tanks?
Get on That!
it sounds like you stat on your heater if fuked i had same problem i had 1 stuck at 30c even on very low setting, depending on size of tank i use a 100w heater in my Jewel 180litre tank but its in my lounge which is always warm anyhow and without heater hold temperature around 20-21c so it very rarely on and doesn't have to work hard to maintain the 24c its set at.
And with the tank having a fully closed lid it keep the heat in
This is mine: it 3x lemon tipped Tinfoil Barbs, ruby shark, silver shark, 6x congo tetras, 10+ plattys, 10+ mollys, royal plec, commom plec, gold nugget plec & joining them soon is 12 various Corys, 4x Hoplo Catfish & 2 glass catfish (the catfish are currently in my holding tank before i move them over to make sure they got no diseases) as my main tank has been 100% for 8 months and don't wanna risk disease.
plus i have 4 breeding mollys, plattys producing 30+ fry every 30 days which go into a baby tank
this is a video of it the Tinfoil Barbs are still growing as i have them sold to a local aquarium
http://www.youtube.com/watch?v=AihMGhmYqWU
Get on That!
But someone i know adapted 1 of those cheap style car fridges 12v/240v to cool his fish tank water he used a sump tank with the cooler in and used an external pump to pump the cooler water up into the main tank only saw the setup once and it look complex lol! and very homemade but it worked
How come your room is so warm? If my room gets above 23 in roasted lol. I tend do have my windows open all the time anyway tho with my rad off.
The tank i have is in the living room. Sorted the temperature out today. I got a new heater and its slowly starting to drop nicely
On the heater i got it can be set to 16 degree.
I have seen some people put cucumber in for the suckers, is this good thing for them instead of always giving them the sinking food?
Get on That!
yes plec like cucumber on a piece of string and remove in morning if they not eaten it all
You need something called a screwcumber... i shit you not, google it and see, about 3 quid from ebay etc
Team HOTHOT!
apples24
12
09-08-2005 04:51 PM
Chrissy_bwoy
29
30-03-2005 01:47 PM
Stu @ M Developments
13
03-11-2004 05:38 AM
