Pectel-problem!!
Old May 4, 2009 | 09:36 AM
olek's Avatar
olek
Default Pectel-problem!!
hello,
i have a 2wd sapp running on pectel t2, and my ecu is at julian godfreys in england and my first event is next sunday...
i have been lucky enough to borrow another t2-ecu, but this has version 1.15 in it, and my box/map is on version 1.17.
because of the diffrent versions i cant load my 1.17-map into the 1.15-ecu, only gets an error when i try.
does anyone have and tricks here, or do i need to type in all the numbers and setting from my map to the 1.15-ecu?
Old May 4, 2009 | 09:49 AM
andrewg's Avatar
andrewg
its maybe like t6 and t6 2000 you can't load them onto each other but there is a way of installing them bit by bit manually
Old May 4, 2009 | 10:04 AM
Martin Hadland's Avatar
Martin Hadland
Originally Posted by olek
hello,
Cant you use the paste buffer function ??
Old May 4, 2009 | 11:39 AM
olek's Avatar
olek
i've tried using the "load paste buffer" function, but the values on the inital v1.15-map doesn't change.
but i will try to erase the map on the v1.15 tonight and do the paste buffer function then. maybe this will help?
Old May 4, 2009 | 12:00 PM
J1mbo's Avatar
J1mbo
B1mbo
make sure all the break points are the same on the map and you might be able to paste them all in
Old May 4, 2009 | 12:36 PM
totalbhp's Avatar
totalbhp
Default T2
You can use map trans program its much quicker and safer than trying to copy and paste every bit
hello,
Old May 4, 2009 | 01:34 PM
olek's Avatar
olek
totalbhp: where can i get that program? seems to be what i need really. is it something that lies in the descprow software?
thanks for all the advice, guys, really appreciate it!!
Old May 4, 2009 | 10:21 PM
olek's Avatar
olek
well, back from the workshop now.
i've managed to get the Load Paste Buffer working (didn't know that i needed to press P to insert the values, lol)
but it seems that the values on the 1.15 is in Fahrenheit and PSI, and my 1.17 is in Celcius and Bar!
so the car starts, but only runs in a second or two.
is there any easy way to change this setup, or do i need to change everything manually?
on the File-menu i have a tag thats called Software Configuration (?), but its blanked out, and i can't press it...
Old May 4, 2009 | 10:33 PM
Martin Hadland
As far as I'm aware different profiles change between metric and imperial values, I have had that problem on T6. Why don't you simply get JG to send over your ECU?
I will take a look at my profiles to see if I have anything suitable. I hate workinging in DegF & psi!
Old May 4, 2009 | 10:44 PM
olek's Avatar
olek
well, i have been trying to get JG to send it to me for the last two weeks...always excuses about pectel themselves beiing to slow etc etc. tried calling them all day today, but they wont even answer the phone!! what kind of customer service is that??
as it would take some days to ship the ecu over to norway, i have borrowed this v.1.15-ecu and will try this, as i REALLY want to drive the car on a trackday @ rudskogen next sunday.
but i will have a second look on my maps now, might have missed something.
Old May 4, 2009 | 10:48 PM
andrewg's Avatar
andrewg
me too!! they also sent mine to pectel,, holiday here to day thou
Martin Hadland
Its a bank holiday over here today so no one wants to work. email me the maps if you wish, I will see if I have any better joy than you.
Old May 4, 2009 | 10:50 PM
james kiely's Avatar
james kiely
its a bank holiday in england today mate
Old May 5, 2009 | 06:26 AM
olek's Avatar
olek
lol! i figured it had to be something. but still, an answering-machine would be great...
will email you later this day, Martin. thanks!
Old May 5, 2009 | 11:24 AM
polly_x's Avatar
polly_x
If you ask Pectel nicely and you are lucky they are in a good mood or even answering emails they will convert it for you to run on a different software version. They did mine.
Old May 5, 2009 | 12:15 PM
olek's Avatar
olek
well, pectel kinda need the ecu at their place to do that, polly x? or?
as this is a borrowed ecu and only a temporary solution i don't want to do that.
time is also a issue here now....
but thanks.
Old May 5, 2009 | 12:23 PM
ian sibbert's Avatar
ian sibbert
Pectel can transpose the map withou the ECU being present pal, as Stu says you just need someone willing to do it for you....
Old May 5, 2009 | 01:03 PM
olek's Avatar
olek
spoke to julian at JGs now and he will convert the map for me, just emailed him the map.
so hopefully it would work!
Old May 5, 2009 | 02:00 PM
Martin Hadland
Have you been messing with the V1-15 map? As all the pressure breakpoints are set to 87psi!! I will sort this later tonight for you if you can wait?
Old May 5, 2009 | 07:46 PM
olek's Avatar
olek
martin: that's what happened when i took the load paste buffer from my original map. wierd hu?
i haven't changed anything manually, just loaded past buffer all over.
if you could fix this it would be great.
