fiesta turbo overboost?
03-05-2009, 04:30 PM
ZETEC TURBO
How far can you push fiesta turbo before it hits overboost????
03-05-2009, 04:36 PM
over boost on what std spec ?? ofab or ofac chiped??
03-05-2009, 05:05 PM
ZETEC TURBO
were will it say that? The only info I can find are xefofbab
Man number v90fb12a650ab
Ser number n199704
All the above is on a sticker remanufactred electronic unit A.T.P if that helps?
03-05-2009, 05:17 PM
I'm pretty sure its 10psi, if its the standard ecu.
03-05-2009, 05:26 PM
ZETEC TURBO
The only mods are exhaust k,n t25 turbo other then that it's STD but it goes to 1 bar on the boost gauge
03-05-2009, 05:39 PM
Are you sure it hasn't been chipped?
03-05-2009, 05:42 PM
Quote:
Originally Posted by
rst-g
look under the glove box and you will see the ecu if theres a chip you will see it .theres no way a standard one will do 1 bar so it must be
03-05-2009, 05:46 PM
ZETEC TURBO
got the ecu out and just looks STD unless the chip is on the board inside? I thought it was mad it pullin 1 bar!
03-05-2009, 05:53 PM
rst-g
ofab will do it but wont hold it for long so put it in 5th at low speed 40ish plant it and see what happens
most likely that your boost gauge over-reads TBH
03-05-2009, 05:54 PM
ZETEC TURBO
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
turbobill
01-08-2015 08:55 PM
