big BIG big Brakes
big BIG big Brakes
Friend of mine sent me some picture's of the latest Mod .. Fitted to his very Sexual and Doughnut Happy F150 HD.
The F150's come with Factory 330mm+ Disc's all - round
Santa Dressed as a Fed-X man delivered them.
Bell + Calliper ..
Disc ... 410mm give or take ..
Braided line's ..
Original 330mm set up ..
Up-rated set up ..
How they look behind the 26" rim's
The rear 340mm (yes bigger than front) behind 26" rim's
Was going to do this up-grade on my old F150 but ... Never happened ..
EDIT: The rotor's are 16" so around 406mm.
Bell + Calliper ..
Braided line's ..
Up-rated set up ..
They Fit behind the OEM 22"s .. Only Just mind ... He said they make a huge difference over the Already Good OEM offering ..
You need the 16" stopper's to stop this thing .. Especially if you remove the 110MPH limiter ..
