Please Help
Old Apr 26, 2009 | 06:47 PM
Kev83's Avatar
Kev83
2.1 ZVH build underway...
Thumbs down Please Help
Right then all, i have a couple of problems with my FRST. Could really do with some help as im hitting blanks now.
Basiclly, when i got the car about 3 weeks ago, everything was sound with it. Ran perfect. However, in the last week, the car has started running badly, to point where it is shocking
First problem is idling. It idle's at 2-2500 rpm once warm and wont drop unless i dissconnect the idle control valve. Im assuming its that, but just wanted to be sure before i bought a new one from ford.
The second problem is the real pain in the arse. When i drive the car, its feels really flat and almost like its missing a touch. After this and it starts to come onto boost, in 1st gear only the car jolts violently and my boost gauge shows very little to no boost. In 2,3,4,5 when you come onto boost it ruins sweet as a nut and pulls really nicely.
At low rpm or touching the accelarator from idle, the car takes a moment to respond. Like a delayed reaction
Any help please people because its really starting to tick me off. To date i have done the following to try and fix, but had no luck
New Plugs (genuine ford), Leads (bosch), Fuel Filter (ford), Crank Position Sensor (ford) full service
Old Apr 26, 2009 | 08:03 PM
105epwr's Avatar
105epwr
have you checked for any air leaks?
Old Apr 26, 2009 | 08:06 PM
Kev83's Avatar
Kev83
yes mate, no luck on that front, everythings tip top
