clutch master cylinder
does anyone know what the bore size on a pedal box clutch master cylinder would normally be, on my fiesta i have a wilwood pedal box with a wilwood pull type slave cylinder, i had to remove the pedals for repair now the clutch wont bleed, so to order a new master cylinder i need to know the bore size which i cant find out on my current setup without removal again!! like on brakes front is normally 0.625 and the rear 0.7 but what about the clutch?
thanks
sean
thanks
sean
