got dyno results help
Old 21-04-2009, 08:54 PM
  #41
trevorcossie
saffy cossie yes
trevorcossie's Avatar
cheers chez hope you get yours back on the road aswell mate
Old 21-04-2009, 08:55 PM
  #42
JTECH James
Passion for Fords!
JTECH James's Avatar
Originally Posted by trevorcossie
how much do you think that will set me back james
you just need to get her in for a health check mate, make sure she is good to go,
then you can look for more power if you want it,
i think a set up at msd is around £150 ish, for that they will set every thing up, and you will know exactly where you stand, the guys there are the best there is imo, and very very trust worthy,
they can tell you exactly whats up, and you will have the piece of mind they wont try to rob you blind
Old 21-04-2009, 08:57 PM
  #43
Paul_RS
Paul_RS's Avatar
Screw the boost up
Whats the spec of the engine mate? Looks to have siemens injectors?
Old 21-04-2009, 08:58 PM
  #44
WongRS
WongRS's Avatar
Originally Posted by JTECHSAFF
everything is fixable, there is no point us guessing whats up with it, we know nothing about the engines spec or history
with a good set up, i reckon you will make more than 360....
the MSD 55lb set up is awesome!
I'll second that, thats what mine is, but on a .48, lovely to drive on thr road.
Old 21-04-2009, 09:04 PM
  #45
trevorcossie
saffy cossie yes
hi the reciepts i have are stage 3 the usaual gear like group a head gaskets . 1000cc injectors . mahle low comp pistons port polish ,31 actuator, l8 ecu and chip ,3 bar map sensor,balanced crank and flywheel ,long stud kit and a few other bits
Old 21-04-2009, 09:05 PM
  #46
JTECH James
Passion for Fords!
bung a t4 on it then!
1000cc injectors are not normal stage 3! lol uou could run 600+ bhp on them!
Old 21-04-2009, 09:07 PM
  #47
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
I just can't get my head round how irregular that graph is. Sometimes if you can't get a nice clean RPM pickup the plot can be a little 'rough', but that operator used Roller speed, so it should have been nice and smooth.
That coupled with it being run in 4th gear begins to discredit the run in any case.
Those things aside, assuming the car had traction on the rollers and the operator was at WOT all through the run, that car has some shocking boost control.
Old 21-04-2009, 09:09 PM
  #48
trevorcossie
saffy cossie yes
do you think there could be a monster in there somewhere ...how do i get in touch with this msd mate
  #49
WongRS
WongRS's Avatar
www.remapping.co.uk, or stu or will on here.
thoroughly recommended mate, bit of a drive for you, but it woul dbe worth every penny.
Old 21-04-2009, 09:11 PM
  #50
foreigneRS
Testing the future
foreigneRS's Avatar
it looks terribly knackered. i think you should sell it immediately before it costs you thousands. i'll give you £3k for it
Old 21-04-2009, 09:12 PM
  #51
JTECH James
Passion for Fords!
indeed well worth the trip, i travel from devon to use them...
may be taking the m5 up there soon
Old 21-04-2009, 09:13 PM
  #52
trevorcossie
saffy cossie yes
thanks fellers .you have helped me right out
Old 21-04-2009, 09:14 PM
  #53
trevorcossie
saffy cossie yes
dont is that a joke .im getting paranoid here mate
Old 21-04-2009, 09:15 PM
  #54
WongRS
WongRS's Avatar
thats what these lot are here for, i exclude myself from that statement as i have limited knowledge!
Old 21-04-2009, 09:16 PM
  #55
Stu @ Claims Care Centre
Compensation Specialist
Stu @ Claims Care Centre's Avatar
dont think he is. the boost looks like its all over the place i know most cosworth have bad boost control but thats terrible
  #56
JTECH James
Passion for Fords!
dont take any notice mate
she will be just fine just needs sorting out, let the msd guys work there magic
Old 21-04-2009, 09:19 PM
  #57
trevorcossie
saffy cossie yes
you dirty gits i be havin nightmares ,, this is why i started that thread the other day .beacuse i thought it was running 360 and i thought if this is 360bhp i cant see the facination ..i need someone to take me out in a real fast stage 3 proper running cossie
Old 21-04-2009, 09:21 PM
  #58
JTECH James
Passion for Fords!
most of them dont work long enough for that
i think your drive home may be "exiting!" to say the least if you use msd lol
Old 21-04-2009, 09:22 PM
  #59
trevorcossie
saffy cossie yes
cheers james really boost my confidence in cossies there mate
Old 21-04-2009, 09:23 PM
  #60
WongRS
WongRS's Avatar
i'd take you for a go in mine if you where closer, it aint mega quick by any means, but you'd get idea, they pin you in your seat pretty well.
Old 21-04-2009, 09:25 PM
  #61
trevorcossie
saffy cossie yes
well i hope mine does i have waited years for a cossie and finally got one thats fucked
Old 21-04-2009, 09:27 PM
  #62
WongRS
WongRS's Avatar
She'll be grand, probably just been a bit neglected and wants some TLC.
Old 21-04-2009, 09:29 PM
  #63
rsnissan
rsnissan's Avatar
get a heat shield on there mate as well
Old 21-04-2009, 09:32 PM
  #64
Paul_RS
Paul_RS's Avatar
Don't listen to the bitter BMW driving EX Cossie owner
Your car seems to have the right bits on it mate, just needs an expert to get them to work together in sweet harmony
Old 21-04-2009, 09:34 PM
  #65
mechanic28
mechanic28's Avatar
what part of london u in
Old 21-04-2009, 09:52 PM
  #66
Chip
*** Sierra RS Custard ***
Chip's Avatar
I cant really see what everyone are on about, the boost control doesnt look too bad to me, sure the line wavers, but only by less than 1 psi of boost most of the time that its wiggling, then just tails off a bit at the top end, probably just a bit of a weak actuator or similar.
Power looks fine to me for the boost level you are running, its not something I would be worried about.
I guess you are in southeast london if you went to sanspeed?
Id say you just need to sort the boost control out a bit, and it will probably be fine.
Old 21-04-2009, 10:02 PM
  #67
RWD_cossie_wil
RWD_cossie_wil's Avatar
Is 4th gear not the ideal gear to run a Cossie on the Rollers as it is dirrect 1:1 drive? , thus leaving out any torque multiplication?
Old 21-04-2009, 10:09 PM
  #68
Christian and Beccy
#1 in Spelling Club
WHY WHY WHY WHY WHY??!!
This has been done SO SO SO many times.
Old 21-04-2009, 10:16 PM
  #69
RWD_cossie_wil
Ok then, so why DOES running it in 4th gear make the run worthless then?
Old 21-04-2009, 11:42 PM
  #70
Steven_RW
Steven_RW's Avatar
cos dyno dynamics rollers state u should run it in 3rd
that is all
RW
Old 22-04-2009, 02:43 PM
  #71
RWD_cossie_wil
that is all
RW
Why? ... Surley you MUST know the torque multiplication to make the calculation complete?
Old 22-04-2009, 02:44 PM
  #72
cooperad
trevs cossie what a tool
cooperad's Avatar
sell the pice of shit and get a new one
Old 22-04-2009, 02:45 PM
  #73
trevorcossie
saffy cossie yes
south east mate whys that
Old 22-04-2009, 03:05 PM
  #74
cooperad
cooperad's Avatar
i think you might need a neww diff mate,
u lost a lode of power form now were
Old 22-04-2009, 03:17 PM
  #75
trevorcossie
saffy cossie yes
do you think so ...i am thinking of taking it to ahmed bayjoo ...i would take it to msd but thats quite far tbh
Old 22-04-2009, 03:29 PM
  #76
cossiebags
220 bhp rs turbo sleeper
cossiebags's Avatar
dont worry lads its booked into torque of the devil on saturday so should come out there sideways if all goes well
Old 22-04-2009, 03:30 PM
  #77
cooperad
cooperad's Avatar
sorry mate with your standard zetec s ill cum flying past you in my mini turbooooooooo.
Old 22-04-2009, 03:37 PM
  #78
cossiebags
cossiebags's Avatar
shove your mini turbo up your ass u mug
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: got dyno results help
