mapping advice please.
Old Apr 12, 2009 | 11:06 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default mapping advice please.
hello all as some of you no my fiesta is nearley on the road (nearley ,lol)
ive just finished fitting my go-tech mfi ecu and loom as i changed from megasquirt, the go-tech was mapped on a a focous rs with 750cc injectors. my injectors are 350cc and its a zetec turbo i no clearly the map is going to be compleatly unsuted to my spec but ive used it to get it up and running ive as i expected it was running lean so i richened it up a bit and got it to idal and my afr's are between 14-15 and my rpm is 900 but it just sounds rough
should i try opning the throttle a bit more and leaning it off or shutting it a bit ect im a bit lost now lol
i have never maped a car befor but im all ways looking into it. so i thort the best way was to have a go
Old Apr 12, 2009 | 11:11 AM
el_man's Avatar
el_man
clark i`ve seen this car get built from scratch scrap it now not worth it hahahaha only joking cant wait to see it running
Ginge !'s Avatar
Ginge !
just finding my feet
speak to jaycos as he maps hes own car and learnt himself too
hes a nice bloke too even if he does like wearing vests
Old Apr 12, 2009 | 11:13 AM
clarke5700's Avatar
clarke5700
first post bigs not bad lol welcum to a proper forum lol
Old Apr 12, 2009 | 11:14 AM
clarke5700's Avatar
clarke5700
lol thanks mate
Old Apr 12, 2009 | 11:18 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Clarke, what ignition values are you using at idle?
Old Apr 12, 2009 | 11:19 AM
clarke5700's Avatar
clarke5700
i had a quick look and from what my crap memory recalls about 10-12 btdc
Old Apr 12, 2009 | 11:22 AM
Jim Galbally's Avatar
Jim Galbally
dave walker's mapping book has a good section on this kinda thing, worth a read IMHO.
Chip's Avatar
Chip
Sounds about right, although if its low comp you might want a couple of more degrees, have you checked with a timing light that its actually getting that amount?
Old Apr 12, 2009 | 11:23 AM
clarke5700's Avatar
clarke5700
ive got that book lol
Old Apr 12, 2009 | 11:24 AM
Chip's Avatar
Chip
Read it then
clarke5700's Avatar
clarke5700
Sounds about right, have you checked with a timing light that its actually getting that amount?
no i havent mite have to pop to work today and grab my light.
Old Apr 12, 2009 | 11:25 AM
Chip's Avatar
Chip
What CR are you clarkey?
10-12 tends to work well in the 8-9 : 1 region IME, if you are low comp though you might want a few more degrees than that.
Old Apr 12, 2009 | 11:26 AM
clarke5700's Avatar
clarke5700
Read it then
words are not my strong point but ill gave it ago
Old Apr 12, 2009 | 11:27 AM
clarke5700's Avatar
clarke5700
im 7.5:1 what should i ramp it up to? or should i ramp it up and see what happens lol
Chip's Avatar
Chip
Do you want me to come round and read it to you as a bedtime story?
Old Apr 12, 2009 | 11:28 AM
Chip's Avatar
Chip
Yeah I would try increasing it a few degrees then mate.
Try 14, see if it sounds happier, you wont kill it at idle even if you do get it wrong.
you may find that it raises the idle slightly as a result too, even on the same side amount of airflow.
Old Apr 12, 2009 | 11:29 AM
clarke5700's Avatar
clarke5700
and the big bad wolf said to the sparkplug im going to huff and puff and blow out your spark
and they all live mapperly every after
Old Apr 12, 2009 | 11:32 AM
Chip's Avatar
Chip
And Mr turbo said, I'll huff and I'll puff and I'll blow your house down
clarke5700's Avatar
clarke5700
ive been told i can run and engine at idal lean enouth till it cuts out with out damaging it. not that im going to try of corse so its going to be a case of fiddling with the idal screw and ignition till i get it right lol
Old Apr 12, 2009 | 11:36 AM
XRT_si's Avatar
XRT_si
Clarke - Ill pop over later if your doing it today?
BTW, your engine WONT be as low 7.5 from memory if your using LET pistons.
Old Apr 12, 2009 | 11:37 AM
Chip's Avatar
Chip
Its not exactly rocket science, you only essentially have those 3 things you can control, so if you cant get that bit right, at least you will have learned that mapping isnt for you
clarke5700's Avatar
clarke5700
realy? dam memory what will it be around? spose i should have realy checked this when building
Old Apr 12, 2009 | 11:42 AM
clarke5700's Avatar
clarke5700
the only way im going to learn tho is but having ago wud you not agree? probaly should use a cheeper engine tho but im only looking at light throttle loads atm the positive boost side of things ill leave to some one else i no
Old Apr 12, 2009 | 11:47 AM
Chip's Avatar
Chip
PMSL @ not having a clue what your CR is, these things should be measured not guess at
Fingers crossed this doesnt end up for you how it deserves to
And yes I agree totally, get stuck in and have a go is the best way to learn
Old Apr 12, 2009 | 11:49 AM
clarke5700's Avatar
clarke5700
yea i no i should have checked this how it deserves to ive spent ages building this i dont deserve to break it
Old Apr 12, 2009 | 01:43 PM
J1mbo's Avatar
J1mbo
B1mbo
when mapping try and find a pattern, map the bottom line first, so no boost just foot on the throttle and hold it at different mapping points,
when you have the first mapping point perfect, look at the next one, it is going to need more fuel obviously so give it some more, then take the engine revs to the next point and adjust fuelling untill its correct
now you can see the jump between them two points, its going to be similar all the way along so add the differece on top of the next point (for a rough estimate), just keep working your way along untill you have all the off boost point nice.
mapping in car is difficult, its much easier on a dyno as you can hold the revs and boost at any point for however long you need, but its not the cheapest way unfortunately !
Old Apr 12, 2009 | 04:05 PM
rst in breaking's Avatar
rst in breaking
mine was down near that with let pistons and a head skim
Old Apr 12, 2009 | 04:21 PM
Ginge !'s Avatar
Ginge !
is that gearbox sorted yet ?
Old Apr 12, 2009 | 07:45 PM
rst in breaking
only really done a few niggly bits today tbh, then went to clarkes. i think its ok but need to get a linkage on as mullgrips ain the answer lol
Old Apr 12, 2009 | 10:18 PM
Ginge !'s Avatar
Ginge !
does it start though now and not stall !!!!
Old Apr 13, 2009 | 12:08 AM
XRT_si's Avatar
XRT_si
Nearly....
Old Apr 13, 2009 | 12:38 AM
Chip's Avatar
Chip
Paul, im probably free tuesday evening by the looks of it if you want a hand with some mapping and its up and running (and got gears, lol) by then.
EDIT : Arse, wrong fucking thread, lol, that was meant for "rst in progress"
Old Apr 13, 2009 | 08:06 AM
Mark V8's Avatar
Mark V8
Don't know anything about go-tec but with Emerald you can scale the whole map to allow for different injectors to save starting from scratch.
Is there not a feature on go-tech to do this ?
Mark
Old Apr 13, 2009 | 09:11 AM
rst in breaking
that would be awsome mate, was dreading trying to make it there as i havnt got a wideband in to check what its doing atm (i know its stupidly rich tho and wet lol, jay was going to load his emerald software and talk me through reducing the injector table. cant wait for it to be driving again (hopefully for the weekend ) i do believe i have all gears now but need to get a linkage of my mates car to borrow , cheers mate
Old Apr 13, 2009 | 09:15 AM
Chip's Avatar
Chip
Text me later and remind me that I need to be taking my wideband away with me when I leave somerset mate, as Im pretty forgetful
Old Apr 13, 2009 | 09:19 AM
rst in breaking
will do, il set a reminder, put it in the car now you lazy git . what time do you want reminding? (id prob txt you after you've left otherwise lol)
Old Apr 13, 2009 | 07:59 PM
clarke5700's Avatar
clarke5700
Mark
yea my mates ecu you can but i dont think i can on my go-tech
Old Jun 5, 2009 | 07:59 PM
clarke5700's Avatar
clarke5700
found this threed so thort i mite as well up date it since i started this threed i just pushed my fez to one side but i pulled it out the other weekend and had a play. it terns out my gotech is broken alltho i bort it under the inpression that it was fine it terns out that one of the coil drivers is broken
so my electrition took it apart and we used one of the spair drivers that is normaly used when running 6 cilinders and swaped them over............
still no luck tho its the ecu its self not firing the driver any one selling a go-tech mfi pro (should have stuck with megasquirt lol)
Old Jun 8, 2009 | 12:48 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
clarke, why did you swop from megasquirt? im in the middle of choosing a system for my zvh build but i really dont know which one to go for
any advice woudl be great mate
