what the f**k. stupid rs
changed starter motor 2nite fir my s2 escort.
jumped it and started. turned it off and on like 3 times and seemed FINE.
the 30mins later i had to move car and done that same fucking thing.
made that wierd clicking sound when turning the key like it did before i changed the starter motor, and on the fuel computer started cumin out with numbers and that.
how can it suddenly do that after starting fine??????????????????
But I put a new starter motor on 2nite. It started fine 1st. Half hour after I tried starting it then it made the clicking noise and wouldn't start?
No way can it completley fuck a brand new starter motor just like that. My old Rs Neva had a shield on and I never replaced starter motor. Fuk spending anuva £60 just like that
check the little spade end wire that goes to the starter motor that this is clean and i mean real clean as this was a problem on mine, in the end i replaced the male spade end clip and it was fine after.
I really think that there is bad earthing sumwhere. Just jumped it and was fine. Starter motor turns over sweet. Really think there is sumwhere with bad earthing ?
sounds like the battery to me. make sure u drop test it to be sure. otherwise its your earth or wiring! i bought a heatshield for the same reason, except mine wouldnt even click. but the problem still occured intermittently hot or cold! did you use a genuine starter? spurious ones cant always handle the heat!
well its been sitting on 11.7v when left for a day.
thats just the voltage reading! ( which is low anyway ) have u actually drop tested it? by drop testing, your putting a load onto the battery, and you can see if it maintains the voltage or not. lucas or bosch starter?
Adam Graham
06-09-2015 06:04 AM
Sierrasideways
15
31-08-2015 10:10 AM
