boost and oil pressure gauges fitting?
![Question](https://passionford.com/forum/images/icons/icon5.gif)
just got my gauges for my saph, got a twin A pillar pod, and a racetech boost and oil pressure gauge, from burton, have got all the necessary bits to fit, but would be grateful if someone could give me a no nonsense guide to fitting them, maybe sum pics?? the cars got all standard hoses and fittings on at the moment, any help much appreciated,
cheers.![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/icon_biggrin.gif)
cheers.
both gauges take the feed (power) from the ignition or ignition feed by kick panel
boost - you have 2 rigid plastic pipes running on top of the inlet manifold, you will need to T piece the pipe which does NOT go to the fuel pressure reg.
oil pressure - you can take this from 2 places, on the inlet side of the block there is the exisiting pressure switch; you can get an adapter and come off of there or some take it from the sandwhich plate
Matt
Matt
JoeyBoyden
18-08-2015 10:52 PM
Escortdriver1
31-07-2015 02:36 PM
