Funny problem, help needed on 51 plate Mondeo TDCi
Just wondering if anyone has had the same problem, drove the car earlier and all was fine, just been out in it and there a funny rubbling noise that i can feel (only)through my left foot when it's resting on the clutch pedal, if i press the pedal 20-30mm the rumble gets worse, but if i hold the revs at about 1300rpm the rumble goes completely. The car has only done 42k miles with full service etc, i bought the car of a mate 10 months ago and he had it from 9k til i had it on 36k so i'm quessing it's still on the original clutch.
Any help or suggestions would be appreciated.
Cheers Ginger
Cheers Ginger
flywheel, clutch and slave looking at just under a grand from ford dealer i'd expect.
however, iirec there is someone on here who will do it for 250 + parts, try a search as it's been covered before.
check gearbox mount hasnt gone and rubbing on subframe.if not you can get conversion putting solid flywheel and damperd clutch,basicly how clutches used to be,hope that helps
sounds like dual mass has started to go mate, loads of motors i deal with at work that have dual mass flywheels all start doing it i think there a very poor design, as said by jb 3 door if you can get a solid flywheel conversion i definatley would.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
