eeciv vs 4x4 plenum
Old Mar 22, 2009 | 10:08 PM
westus1's Avatar
westus1
Default eeciv vs 4x4 plenum
how do you tell the differance between
a 4x4 saph/big turbo escos plenum
and a small turbo escos eeciv plenum
i know the differance between 2wd and 4wd but never paid any
attention to the small turbo plenum?
is it a direct fit to a 2wd trumpet section,
i'm sure the sensors are differant but can they just be swapped over?
basicaly what needs done to fit it?
Old Mar 22, 2009 | 10:11 PM
Twellsie's Avatar
Twellsie
eeciv has the take offs on the front, 4x4 has the take offs on the side, i believe
Old Mar 22, 2009 | 10:12 PM
westus1's Avatar
westus1
what d'you mean on the front mate?
thepintoman1's Avatar
thepintoman1
eec4 hasnt got the hole for the sensor (sp) on it and they have the air takeoffs on the ends
Old Mar 22, 2009 | 10:13 PM
Twellsie's Avatar
Twellsie
as you look into the engine bay, they are on the face of the plunum, directly infront of you
Old Mar 22, 2009 | 10:14 PM
westus1's Avatar
westus1
cheers mate
can the intake air temp sensor be fitted?
or does it need a boss welded in?
Old Mar 22, 2009 | 10:19 PM
thepintoman1
get a boss welded in mate
Old Mar 22, 2009 | 10:20 PM
Twellsie's Avatar
Twellsie
they are pretty thick, so would imagine you could just drill and tap it, but i am not sure
Old Mar 22, 2009 | 10:34 PM
westus1's Avatar
westus1
cool,
chears guys
Old Mar 22, 2009 | 10:38 PM
Kevin Sharp's Avatar
Kevin Sharp
i have one sitting here, i will take a pic tomorrow and post it up if someone hasnt already
Old Mar 23, 2009 | 12:50 PM
WD Pro's Avatar
WD Pro
Thats how mine has been done
Old Mar 23, 2009 | 01:03 PM
Ryan's Avatar
Ryan
air temp can be tapped and drilled into the back of the EECVI inlet.
Old Mar 23, 2009 | 01:07 PM
carlo's Avatar
carlo
I had one & sold it but it was tapped into the normal place & looked factory , you have to drill the throttle body holses out slightly but not a big deal
Old Mar 23, 2009 | 01:10 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
You can drill and tap the cover in the same place as std 2wd/4x4 for the ACT sensor. As said before the air takeoffs are at the front and back of the plenum cover.
All of the trumpet sections are the same, 2wd, 4x4, Small turbo all smae so any cover will fit any
Your throttle body holes will need opening up from 6mm to 8mm to clear the bigger bolts the EECIV plenum uses.
Dan
Old Apr 8, 2010 | 02:30 PM
DaveCrack's Avatar
DaveCrack
I am just changing from 2WD to eeciv plenum and need to drill and tap it for the act sensor. Does anyone know what thread size the sensor has?
As its quite difficult over here to get NPT or BSP thread taps I want to get it right the first time.
Thanks!
Old Apr 8, 2010 | 04:24 PM
jon@work's Avatar
jon@work
Thanks!
luckily for you it's M14 x 1.5
Old Apr 8, 2010 | 04:28 PM
jon@work's Avatar
jon@work
I had a boss welded as shown in pic below :
Old Apr 9, 2010 | 09:37 AM
DaveCrack's Avatar
DaveCrack
Great! Thanks for the answer!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
