Focus RS rear beam on escort mk5
Ive been toying with the idea of fitting a focus rs rear beam to my escort project so it handles alot better than the crappy rear beam on escorts.
Obviously this will take abit of fabrication work but i just want peoples thoughts on this, is there anything you can think of that will make this a pain?
Also does anyone have underside pics of a focus rs and a escort mk5 so i can compare
cheers matty
cheers matty
Forgot to say also, that the frs beam is the same as a standard focus except for the uprights which are 20mm wider each side. Brakes are same as ST170 rears. (Which may be the same as 1.8/2.0L with discs - can't remember).
Chris
Chris
thanks for your reply, i understand the floor pan will need fabrication work which i understand, it shouldnt cause to much problem as my car is only a shell atm and im sending it of for fabrication to fit my focus rs engine so it can all be done together.
also im after a rs one as my escort has a cosworth kit fitted so the width will be a help.
realy i need pics of the underside of both if possible so i can get a idea of where to start
main reason i want to do this as it should ad a much better drive
fwiw, i'd buy a standard focus beam (with discs) which will be miles cheaper and just run spacers. you could ugprade to frs rear uprights when it suited. would expect this to be cheaper than a complete rs beam.
will have a dig about in the pics i have..... have you look on ffoc?
Chris
Chris
Here,s pics of my focus st170 rear beam that iv,e just got to upgrade my focus rear drums to discs.
![](http://i35.photobucket.com/albums/d192/minter123/345a_1.jpg)
Only help I can be at the moment,
Forward Blade mount inside view focus estate
Wide view focus estate
regards to the questions of which beam to use either the st170/rs one will be fine im not botherd, dont want to get a standerd focus one as i want the bigger st/rs brakes to come with the beam
murcury, is there any chance you can get pics of under your focus when ur changing your beam? will be good if you could get pics with std beam on, with no beam on and with the new disc beam just for comparison reasons
cossi will, it would be easy to buy a normal cosworth yes, but it wouldnt be a project then. also it winds me up when people say whats the point in doing a rep, if my mk5 escort didnt have the cosworth kit on id suspect id get alot of good comments for putting a focus rs engine in it etc but just because it has a wide body and whale tail its pointless
either way ill be driving it every week rather than locking it up in a garage 9months of the year
Could you get a standard focus rear beam from a scrappy just for trial purposes? Shouldn't set you back too much and could be sold on later (or converted to the bigger brakes).
Chris
Chris
Escort Mk6 Rally Maxi
This guy has started making them for the Mk6 escort Andrew@A.L.D http://www.sportingfords.com/forums/...p=32153#p32153 and depending on spec depends on the price but they start at about Ł500 I think.
He has a whole topic on it on the link above and alot of other stuff as well like engine work etc.
![](http://img3.uploadhouse.com/fileuploads/3145/31455532dc440dc797a10c95877da7e5c981db2.jpg)
Finished beam pre powder coat
just looked at the prices Ł500 for the cheapist and Ł1000 for the best.. for Ł1000 it will be alot cheaper to use a focus beam with a bit of fabrication surly?
is it independant though? or just adjustable? i want each wheel to move freely so the car has more contact with the road, which the focus setup will give me, but the beam pictured looked like its bolted and just bushed unless its Spherical Bearings?
it would be great if i the maxi beam is as good as it looks will save on fabrication but i cannot find much information on it atm, i have emailed the guy im just waiting on a replay..
you can be a cunt at times... yes obviously both sides or the beam are seperate but i cannot tell from the pic whats holding it together, weather its bush's or Spherical Bearings... that will make all the difference..
projects are about learning as you go on, im enjoying my project and learnt alot so far considering i have no mechanical experiance what so ever and have sucessfully built and repaired engines for my motorbikes and on my zetecs.. yes maybe some of the most basic engines available but i have not learnt anything of any of your replys unlike some of the more helpful passionford members
so please infuture dont comment my threads unless your going to help..
Colossal Pervert
McGoo 69- Don't take what I say personally. I think you have misunderstood the nature of my comments (and perhaps elsewhere also).
I look at someone who wants to do a radical change to the rear suspension design. I would expect that someone doing so would understand a certain amount about suspension design to fully understand the pro's and con's of such a change.
My comment, expanded upon, means that if you're not fully aware of what is actually going to change, then perhaps this is not something you should be changing. It's a lot of work and if you're not familiar with how it will change things on the car, then perhaps the result may not be what you expect?
The Special One
I had a custom-made hybrid beam made for my MK6 Escort some years back by Pumabuild. Cost a packet, but was superb. Sold it on to a lad last year, who then fitted it to his car and chopped it in. Very much doubt whoever owns it now realises just what's lurking under there, lol
Do you have pictures of that beam
i realise you are a very clued up fella but sometimes this gets the better of you when us who do it for a hobby need help.
Thanks for help 1st and 3rd replys
ive been in talks with the builder and hes been very helpful these are the 3 options for anyone intrested
The basic spec is Ł650 ( Ł550 if you send your beam in ) as seen in the picture, your lucky as i have some Mk5 beams ready to work on
Then there is one with a universal ARB, but this needs some small fabrication work on your side as some mounding brackets will need welding to the car and some drop links making Ł850
Then Ł1000 for a full rose jointed beam with the above mods
he reccomended the 2nd option to me as mine will be a road car with the occasional track day, the 3rd option can be hard to live with for everyday use.
pics would be great mate
how much did it set you back may i ask?
was it similar to the one above?
The Special One
It wasn't like the Maxi beam mate, not as "harcore" as that, it was more intended purely for "fast road" use. I originally just wanted a new beam to accept rear discs, but then got chatting about options and it was something similiar to the Racing Puma beam (it used part of that) and then hubs and brakes from an ST170.
It cost circa Ł800 about 4 and half years ago.
I never got any pics of it as they made and fitted it and there it stayed until the lad took it away when I wasn't present.
I know the lad took a pic just before fitting it to his car though, so I'll try and track that down.
![god](https://passionford.com/forum/images/smilies/dieu.gif)
yeh ive been with talks with him on that other forum, its going to be featured in fast ford soon which is promising. going to be ordering one when i get back of my holidays i think
Pictures taken from another site that he posts on and here are the pics that might be used in the mag?
![](https://img.photobucket.com/albums/v607/andylindley/image-1.jpg)
![](https://img.photobucket.com/albums/v607/andylindley/image.jpg)
155lee
14-09-2015 07:37 PM
155lee
14-08-2015 11:21 AM
