What to look for when buying a Discovery?
I know this is a Ford forum but your all very knowledgeable
Going to look for a mid 90's Land Rover Disco tomo anything in particular to look for?
Guess they rust like fook? and diffs/transfer boxes etc.
3dr Cosworth owner
Lift the boot floor carpet up. the first thing you should do. put the back seats forward all the way and look under the carpet there too. Prone to rotting there. also there is an inspection plate in the boot, the fuel tank is under there and the fuel pipes rot out there too. check sill and rear chassis rails. Also check for lash in the gearbox and make sure you try it in low and high box and diff lock etc etc
basically they rot everywhere, i have about 7 i am breaking, as said boot floors, rear body x member and mounts, inner/outer sills,rear inner arches near the seatbelt mounts, floors round the seat bases and seatbelt mounts, inner wings, front body mounts, complete rot boxes, try looking for a jap import one, mechanically they are pretty good the 300tdi,s are a bit prone to cracked heads
maybe better keep your eyes open for an early TD5? i bought 2 within the last 6 months for under £1500.....
well depends what your using them for, i had a shogun for 4 years and it was a good car..then i drove a 4.2 landcruiser and the shogun was crap in comparison.
if its for using offroad the landrover is the best of the bunch straight out of the box....if you can find a 300 disco without much rot
Thanks for the info guys, I looked at shogun pajeros but you look like a complete pikey. Doesnt bother me but does the mrs
Found a rot free 300tdi, bit of superficial on body work but nothing major and has had a new boot floor. And no gearbox noises whatsoever!
thanks again.
thanks again.
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
