Whats does jailbreaking an iPhone do and how do you do it?
Well essentially it allows you to use a 'non o2' sim card and also you can install 3rd party applications without having to use the appstore.
Pro? Well u can use a different network card
Con? Well none really, as with itunes you can fully restore your iPhone back to factory anyway
UNLOCKING unlocks the NETWORK - to use a sim card from a different carrier
However, you cannot unlock the network without jailbreaking - 2G phones this is built into the jailbreak proceedure, and 3G phones is a seperate "app" downloaded after jailbreaking.
You don't have to unlock it if you jailbreak.
As for pro's and cons. Pro's are that you can really begin to use the full potential of the software that is the iPhone OS. Third party apps that can customise virtually any part of the OS, change it's appearance, do loads of different things with it - even switch to Linux!
Con's - the only real con is that whenever you upgrade to the latest Apple firmware, your phone gets un-jailbroken and you have to jailbreak all over again, and then download and install all your apps and plug ins/tweaks all over again.
ELASTIC BAND
Is there no back up application then?
Something like spb backup ( for windows mobile )
Basically i install the program, do a backup, which saves a file to the memory card.
Flash the mobile with a new rom, then run the file on the memory card, 20mins or so later, all my programs, files, ringtones, appointments, tweaks, background picture etc is back the way i had it on the old rom.
must be a 3rd party app for the iphone like this??
There is an app (a jailbreak one) called APTBACKUP that caches a list file and when you sync with iTunes (iTunes always does a backup before a sync) it stores the file in the backup. When you next restore, the list is carried back to the phone and you download and run the Aptbackup app and it *should* download and install all the jailbreak apps in one go. I'm actually just trying it now as I just had to restore my iPhone. Last time I tried it, it didn't work, so shall see what happens this time....
But you still need to jailbreak and unlock everytime you upgrade to new firmware (ie, upgrading the iPhone OS from 2.0 to 2.1 > 2.2, etc
And you need to wait each time for the Dev Team to crack the new firmware code to allow you to jailbreak and unlock the baseband.... It's easy enough to do, and doesn't usually take long for the hack to be available, but it's not as quick, nor as simple as just having a "regular" iPhone and doing a "normal" firmware upgrade....
