metering head problems ????
Old Nov 30, 2004 | 09:58 PM
220TC's Avatar
220TC
Default metering head problems ????
quick question, if a s2 erst metering head was fucked would it play up all the time or just when starting the car
The car takes a good 30 - 40 seconds of cranking before it splutters into life, once started it drives fine with no missfires but I have noticed a low idle and lots of 'rumbling' when you lift off the throttle.
Or does this sound more like a problem with the fuel ecu ?
cheers, Duncan
Old Dec 1, 2004 | 07:02 AM
220TC's Avatar
220TC
Old Dec 1, 2004 | 10:05 AM
220TC's Avatar
220TC
anyone ?
Old Dec 1, 2004 | 10:22 AM
CabrioTurbo's Avatar
CabrioTurbo
To be honest mate there are loads of things that could effect the start up.. i know youve ruled out a lot of them however its prob best to just take the car to a tuner and say 'fix it' chances are they will sort the problem in half an hour!
If the car ran fine before the head gasket change then there is no reason why it shouldnt afterwards.. only the things youve moved should really effect it.. (assuming youve put the head on properly) ie dizzy, and cam timing..
I know things can go wrong at the smae time.. ie fuel ecu, metering head etc but this is very unlikely..
I wouldnt want to go to the hastle of changing the metering head unless i was sure that was the prob..
Old Dec 1, 2004 | 11:21 AM
220TC's Avatar
220TC
I know mate, I really hope it isnt this as its supposed to be getting set up tommorow I've got a different fuel ecu to try when I get home so maybee that might work, someone did mention to me that starting the car off jump leads can kill the fuel ecu, anyone know why as my car was started with jump leads loads of times after the headwork etc..
Duncan
Old Dec 1, 2004 | 11:23 AM
Stu @ M Developments's Avatar
PassionFords Creator
Sounds like a blown heated seats fuse.. lol
Old Dec 1, 2004 | 11:43 AM
220TC's Avatar
220TC
I've checked that stu and its ok, I've got a different fuel ecu to try when I get home tonight so maybee that will work, I cant think what else it could be
Old Dec 1, 2004 | 11:45 AM
220TC's Avatar
220TC
also, anyone know the answer to this ?
Old Dec 1, 2004 | 11:46 AM
Coolant sensor?
ThermoTime switch?
Aux Air Device?
You sorted em all?
Old Dec 1, 2004 | 11:56 AM
220TC's Avatar
220TC
Coolant sensor?
ThermoTime switch?
Aux Air Device?
You sorted em all?
not checked coolant sensor yet, is there any way to check these or is it just a case of buying a new one and installing it ?
thermo time switch.....I disconnected the cold start injector and there was no difference, does this eliminate it?
aux air device, I took the pipe off from underneath the throttle body and blew down it, there was no resistance so I'm assuming the aux air device is working as it should be and open when the engine is cold.
Duncan
Old Dec 1, 2004 | 12:12 PM
Sounds good so far.. best you check teh black box actually works then eh?
P.S.
I think we covered the wiring plugs in another post didnt we?
Old Dec 1, 2004 | 12:15 PM
bassboy's Avatar
bassboy
mine done this and it was a leaking injector...changed the injector car ran fine...now another one is leaking LOL...but i do find if i can catch the engine on the first turn it starts first time otherwise im there for a while as well
bassboy
Old Dec 1, 2004 | 12:29 PM
220TC's Avatar
220TC
yes we did as it has one of your 5th injectors plumbed in via the cold start
I'll try the fuel ecu, if that dosent fix it I'll try a new coolant sensor and if that dosent fix it I dont know what I'll do
dombanks
Sep 21, 2015 08:38 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
