Is there any advantage of siemens injectors over Greys?
Ok I know the Siemens ones are more modern and a better design, what I really want to know, is for a spec. just beyond syage 3, greens etc, is it REALLY worth going for Siemens injectors or is that better suited to a higher specced car? If you see my point!
so if the power is wanted beyond that you might as well go for siemens
all siemens are the same price, 55's, 72's and 83's, so may as well go for the biggest incase you want more power in the future
ah just read what ya posted probably dark greens are in general running close to the max on stage 3,although they are fine for this power level!are you already on stage 3 or planning to go to it?
PassionFords Creator
I can get usually the fuelling every bit as good on greys as I can Siemens so if you allready have greys and they are suitable for your conversion, dont change. If you dont, then buy Siemens.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
