PC memory
Old Nov 30, 2004 | 02:57 PM
James Raby's Avatar
James Raby
Default PC memory
Will PC133 memory work in a PC that previously had pc100 memory sticks??
Old Nov 30, 2004 | 03:03 PM
CabrioTurbo's Avatar
CabrioTurbo
If the motherboard is Pc133 compliant then yes.. unlikely though as it would probably of been used in the first placee instead of the PC100
Old Nov 30, 2004 | 03:10 PM
James Raby's Avatar
James Raby
Well, appears not as it ain't starting up LOL
Here's my PC spec...
http://support.packardbell.com/uk/my...rnr=t742700310
Old Nov 30, 2004 | 03:41 PM
EvilFranky's Avatar
EvilFranky
It shouldn't make any difference to be honest, the motherboard should just clock the PC133 RAM down to PC100.
Well in my experience thats whats happened.
Old Nov 30, 2004 | 03:43 PM
James Raby's Avatar
James Raby
What's up with it then ROFL
Old Nov 30, 2004 | 03:52 PM
Jim Galbally's Avatar
Jim Galbally
as per franky, it should work anyway... unless your mobo is proper shit! (which it must be if its sill taking DIMMs... lol)
Old Nov 30, 2004 | 03:56 PM
CabrioTurbo
Processor Host/Bus support (66/100/133 MHz System Bus frequency, 32-bit system bus addressing, GTL+ I/O buffer).
It should work fine!
Old Nov 30, 2004 | 03:57 PM
James Raby's Avatar
James Raby
Well, to me that means I may need a newer motherboard???
Old Nov 30, 2004 | 03:58 PM
James Raby's Avatar
James Raby
It don't work though
MSN anyone LOL
Old Nov 30, 2004 | 03:59 PM
CabrioTurbo
what doesnt work.. doesnt it boot up? ie JUST black screen no bios or anything?
Old Nov 30, 2004 | 04:01 PM
James Raby's Avatar
James Raby
Just blank screen, doesn't even turn monitor off stand-by mode
It's starts the PC up (power button) but don't go no further
Old Nov 30, 2004 | 04:06 PM
Adrian's Avatar
Adrian
Put the largest memory chunk in the first slot then add the next smallest next to it.
Then try.
Also, are you sure you have connected it correctly? Does it click into place?
Old Nov 30, 2004 | 04:10 PM
CabrioTurbo
i was gonna say you sure you got it the right way round!
Ive put it in (forced more like! ) the wrong way (ooo er! ) and it burnt the motherboard!
I know its almost impossible to do.. but i did it!
I was hung over though!
Old Nov 30, 2004 | 04:11 PM
Adrian's Avatar
Adrian
Guy at work done that on a G4 Mac
Old Nov 30, 2004 | 04:12 PM
James Raby's Avatar
James Raby
Ade, I have 2x256mb PC133 SDR/CL3 cars to insert, they click into place nicely, once is higher than the other though in actual size
My old card says PC100 but it's also CL2
Old Nov 30, 2004 | 04:13 PM
James Raby's Avatar
James Raby
Will only go in one way round due to the gold pins at bottom, Ade I haven't got your number, wanna ring me?
Old Nov 30, 2004 | 04:14 PM
Adrian's Avatar
Adrian
Try a PC100 chunk with a 133 see if it makes any difference.
You could have a piece of fucked memory.
Old Nov 30, 2004 | 04:16 PM
James Raby's Avatar
James Raby
I have tried putting one of the new chunks in (main?) slot and old one in other and vice versa using all different ways
It will only recognise the old one
Old Nov 30, 2004 | 04:17 PM
Jim Galbally
from what cabrioturbo posted, it should work
unless your motherboard requires your processor clock speed to match the memry clock speed? i know a few shitty ones do
also has the mobo got jumpers on it? you may have to set the clock speed on there manually...
James Raby's Avatar
James Raby
Jim, that is way above my head LOL
Old Nov 30, 2004 | 04:22 PM
Daveyboy's Avatar
Daveyboy
i would try them one at a time. might not like working in pairs. Does the machine beep at all when you boot it up? might have knocked video card loose... happens a lot
Old Nov 30, 2004 | 04:24 PM
James Raby's Avatar
James Raby
Nope, cos works when I put old one back in - it's this PC I am typing on that I trying to sort LOL
Old Nov 30, 2004 | 04:29 PM
CabrioTurbo
you will have to look in the mother board manual and see if it has 'jumper settings' in there.. they are just little conectorsa which need swapping over dependant on the clock speed.. i know my old P75 needed this doing.. but the old P3 packard bell motherboard i had didnt..
Old Nov 30, 2004 | 04:34 PM
James Raby's Avatar
James Raby
I have no real manual and wouldn't know what I'm doing
Old Nov 30, 2004 | 04:37 PM
James Raby's Avatar
James Raby
Just looked, just an install guide for my PC (basic start-up from new stuff)
Nothing else
Kam B
Sep 24, 2015 10:40 AM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
dvid
24
Dec 8, 2004 11:01 AM
soulweavers
Computers, Consoles and I.T.
Aug 1, 2004 09:03 AM
