Wiring Loom builders......
What do you use for passing an engine loom through a hole in the bulkhead? I can't find a strong bulkhead grommet for this purpose. I think I want a normal panel grommet, but with a tail that can be built and sealed into the loom, if that makes sense. Suggestions?
Help!
Help!
Personally i used a 32mm rubber grommet i had in my van (i'm an electrician), as the 32mm ones are fairly hefty ad plenty of room for the loom and gauge hoses...however there's no tail on these, didn't see it as much of an issue as the hole was fairly high behind the blower motor so no chance of water getting in. Have a look at this site....they even offer free samples http://www.plastic-parts.co.uk/mss/m...S-6TMAT5-04034
Mark RS
12-10-2015 06:01 AM
muz
30-09-2015 08:29 AM
